Go to Post I want to use some of that mass-less rod in our robot - saves weight. - ebarker [more]
Unread 11-08-2012, 20:46
Pauline Tasci's Avatar
Pauline Tasci Pauline Tasci is offline
Rockets and Robots
FRC #3476 (Code Orange)
Rookie Year: 2010
Pauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond repute
Gearboxes? Help!
Hi! I'm Pauline from 589 Falkon Robotics. Since our inception in 2001 we have been using the AndyMark toughboxes a lot! I believe one year we created our own custom gearboxes and it went great, but that was over 5 years ago.
I am the head of the whole drive system team and really want to either build our own gearboxes or use better ones than the andymark tough boxes.
Don't get me wrong the Andymark toughboxes are awesome! Though we have been using our robot more and more every off season and the andymark ones are simply not holding up.
Any suggestions? Anything would help! Thank you!
Team 3476 Code Orange- 2014-? ~ Head Mechanical and Design Mentor
FIRST Orange County 2015-? ~Regional Planning Committee Member
Beach Blitz 2016-? ~ Event Chair/Director
FIRST Volunteer-2010-?
Team 589 Falkon Robotics- 2010-2013 ~Captain, Driver, Outreach, Mech Lead
CD Moderator~ Always feel free to PM me.
Facebook
Unread 11-08-2012, 20:51
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Gearboxes? Help!
Can you describe the failure you are experiencing. Pictures are a great supplement as well.
We make custom gearboxes for almost every system, and most are nearly identical in AndyMark in terms of what would wear out or fail.
If you're experiencing failure it's likely lack of grease, foreign debris causing issues, misalignment causing gears to clash, etc...
Unread 11-08-2012, 21:10
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Are you asking for alternative gearboxes or an explanation on custom gearboxes?
If you're looking for alternatives, I would highly recommend CIMple-box, the ones that were in the KOP in the last two years. They're really sturdy, and even though they have only 1/3 of the toughbox's reduction, we got great speeds and intense pushing power with them.
If you're thinking of custom, I can't help unfortunately
Unread 11-08-2012, 21:16
Rockets and Robots
Rookie Year: 2010
The thing is we have had professionals look at the boxes (we broke down on a sponsor trip at an engineering company..so awkward). We applied as much grease as we have in years past, actually more than usual. My theory is just it had so much strain on it that is caused a misalignment in one of the gears. The mentor who is an expert on drive systems simply explained that "these gearboxes are only meant to last through competitions, we have used [our robot] more than any other. "
The pictures are here: http://imgur.com/A4mus,yHWxC,7Fs1Z,o...FlA T,RYjzn#1
Not all the pictures of parts have problems, I just decided it would be better to take pics of everything.
Facebook
Unread 11-08-2012, 21:17
Rockets and Robots
Rookie Year: 2010
cimple boxes? I actually have built a few for testing code in the beginning of season? how many of them did u use on the drive system? one on each side?
Facebook
Unread 11-08-2012, 21:29
bardd's Avatar
That loud guy
AKA: Bar Danino
Rookie Year: 2011
Yes, and the same last year. In 2011 each powered three wheels, in 2012 four.
In fact, we were using the ones from 2011 since we got them until about a month ago (we're on a break), and they still work great. we used them on average about once a week for a few hours.
Again, highly recommended
Unread 11-08-2012, 21:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Those appear to be the picks of a gearbox that was never properly greased.
Unread 11-08-2012, 21:38
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
That's what I said.
edit: Once it starts wearing down, it's a perceptual process. The ground up gear particles gets between the gears and further grinds them up.
Yes, the ones we used on the 2011 robot. They still work wonderfully. Second statement was not a question. From what I have observed on CD, most teams use 4 CIMs; 2 per gearbox.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 11-08-2012, 21:40
Andrew Lawrence
Posts: n/a
I second this. I've looked through multiple gearboxes for use on our robots, and through all of them, the CIMple Box is by far one of the best. Very reliable, easy to mount, and saves teams a lot of money/time when designing a robot (no need to order different gearboxes, these come in the kit of parts!). 1 per side, and your drivetrain will be trucking all year long.
There's a reason that 1114 used CIMple Boxes in their Kitbot on Steroids. They're amazing.
Rockets and Robots
Rookie Year: 2010
How can they work perfectly fine for over 3 months and then all of a sudden just progressively get worse if it was not properly greased in the first place?
How did it operate correctly for such a long time?
Sorry, not trying to sound rude, I just really want to figure it out to insure it does not happen again!
Facebook
Unread 11-08-2012, 21:42
Rockets and Robots
Rookie Year: 2010
One per side? Hmm.. I guess I can try it during off season. What is different about it that makes it so reliable?
Facebook
Unread 11-08-2012, 21:58
IndySam's Avatar
Hard to say, just luck.
I don't see any grease on the gears or in the gearbox housing, and the condition of the gear and the shavings in picture 17 are classic signs of an improperly greased box.
Andrew Lawrence
Posts: n/a
Like the name suggests, it's very simple (3 gears, 2 of which are on the CIM motors), only 1 stage, so it's more efficient, and because of its simplicity, there are little to no possible failure points.
Just BE SURE TO GREASE THEM. (Caps and bold for emphasis)
Unread 11-08-2012, 22:02
Rockets and Robots
Rookie Year: 2010
hmmm okay! I'll for sure try it!
Facebook
  #15   Spotlight this post!
Unread 11-08-2012, 22:03
Rockets and Robots
Rookie Year: 2010
Alright! That would explain a lot! I'll look over the other gearbox and see if the same thing has happened! thank you!
Facebook
