Go to Post Avoid the impulse to shoot from the hip, and find out the full picture before deciding where you stand. - gblake [more]
Unread 22-08-2012, 20:58
ABA's Avatar
ABA ABA is offline
FRC #1153
ABA is an unknown quantity at this point
ACER ICONIA
does anyone know if the ACER iconia tablet with windows 7 will work as a driver station?
Unread 22-08-2012, 21:00
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
Re: ACER ICONIA
I believe if it can run LabVIEW it can work as a driver station
Edit: I completely forgot about the ethernet port... But yes you will need one, or a least an adapter that you can test with the field
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 22-08-2012, 21:09
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: ACER ICONIA
Originally Posted by nukemknight View Post
Any tablet running an operating system compatible with the Driver Station software (Currently Windows XP and 7) will work, but as already stated it must have an ethernet adapter and at least one USB port.
That being considered, you would have to use a laptop-style tablet. I'm not sure why you would go that route unless you plan on a touchscreen being integral to your DS setup.
Quoted from the other thread that you started where you posted a near identical question. Did the above answer not suffice?
Originally Posted by ABA View Post
does anyone know of tablets that work for driver station?
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 22-08-2012, 21:50
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: ACER ICONIA
I see no reason why it shouldn't... assuming it has an ethernet port. I suppose if it doesn't have an ethernet there are USB adapters to solve that problem, but that's not an ideal solution and just adds points of failure.
On the other hand, the same company that makes the KoP netbook also has a touchscreen hybrid variant with a screen that can fold over into a tablet formfactor:
http://ctl.net/laptops/netbooks/2go-...pc-nl3-ec10is2
Pro-version (more expensive):
http://ctl.net/laptops/netbooks/2go-...nl3-pro-tablet
And here's the traditional DS netbook:
http://ctl.net/laptops/12-inch-and-s...pc-e12-es10is2
To be honest, I'm just not sure how much utility a touchscreen would be (and it would certainly depend on the game), but if it's something your team is interested in and you think it'll be useful then go for it.
For the record though, I do think something like the hybrid classmate would be more appropriate (and I'm sure the FIRST officials would agree) because of the hard-coded emergency stop button. And unless you find a good way to secure the Iconia you might find lugging it around on a fairly heavy driver station where you have no possibility to catch it if it fell is a bit precarious.
