Go to Post the chicken crossed the road because it was a boundary. it wanted to demonstrate the spirit of FIRST by crossing that road. - Mike Ciance [more]
Unread 01-10-2012, 23:06
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Rookie Year: 2000
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: WCD vs Standard
Don't weld or weld near bearings. The grease has a bad habit of lighting on fire.
Originally Posted by LedLover96 View Post
So you do want to put your smaller wheels farther to the outside, to widen your wheelbase? Putting them in the same spot you would put an 8in wheel would be pointless, I am assuming, because the wheel base would be the same, but you wouldn't get better speed?
And what is "press fitting"? Could you elaborate.
You need less gearing for 4" wheels though, and they have a lower mass (and therefore moment), so it can save you weight even if you don't put them further out on the frame.
Press fitting refers to having a hole that's just slightly smaller than the diameter of the bearing, so when you press it in, it doesn't come out. It's kind of tough to figure out what size hole to make and then make it accurately (within a few tenths).
Unread 01-10-2012, 22:50
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: WCD vs Standard
I have read somewhere that you use 4in wheels to save weight, go faster, and keep your wheels as far to the outside as possible. Is this true? Should I design my WCD to use one type of wheel?
Also, can you weld the AM Flanged bearings to standard aluminum wall? (6061 I think).
Thanks!
Smaller wheels will in fact make the robot go slower at the same gear ratio. Wheel size shouldn't be considered in terms of speed, as you should be adjusting your gear ratio to account for the wheel size. However the 4" wheels will save weight and widen your wheelbase, as opposed to 6" and 8" wheels.
Typically, teams press fit bearing, as opposed to welding them.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 01-10-2012, 22:56
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Rookie Year: 2010
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: WCD vs Standard
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 01-10-2012, 23:00
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Re: WCD vs Standard
Press fitting usually means (at least how I have interpreted it in FRC) the hole is slightly undersized such that the bearing needs to be pressed in quite hard, this will result in a tight fit that will hold the bearing in place.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 31-08-2012, 03:34
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: WCD vs Standard
Originally Posted by MattC9 View Post
Do you have solid proof that WCD are lighter than any other drive?
Matt,
I can't think of another drive that would be lighter than a WCD other than a super pocketed sheet drive. I'm curious to see the weight comparison and sheet drive.
But WCD is decently light due to the fact:
-No outer Railing
-Minimal amount of parts.
-Smaller parts: Wheels/Sprockets/Gearboxes etc....
We switched over to WCD in the fall of 2010. Never looked back (thanks 973!), its such a nice system that 254/968 has perfected over the years.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 31-08-2012, 09:13
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: WCD vs Standard
While not the traditional wcd, doing one with fixed wheels and belts would without a doubt result in the lightest drivesystem in FIRST.
That said there is really no right or wrong answer. Do what works best for you. If your main manufacturing resources are sheetmetal then WCD might not be the best choice. It is possible and we have actually run a sheet WCD before but it's not the best use of resources.
Mentor 2415
