Go to Post A lot of people posting without first hand knowledge, that's fun. - Aren_Hill [more]
Unread 29-08-2012, 20:12
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Rookie Year: 2010
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
WCD vs Standard
What is the advantage of a WCD over a standard drive? Why would you choose to do a WCD 8 wheeled or WCD 6 wheeled over a standard 8 or 6 wheeled drive?
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 29-08-2012, 20:14
Re: WCD vs Standard
Hey Walter,
There are several threads that discuss the pros and cons of each style of drive. I search should yield you the results you are looking for.
Let us know if you can't find them.
-Akash
UAH Class of 2019
Rookie Year: 2010
Re: WCD vs Standard
I tried finding them, but only found WCD vs. Swerve and many pictures of a WCD.
Unread 29-08-2012, 20:17
Andrew Lawrence
Posts: n/a
Re: WCD vs Standard
Some things I've found on my way asking the same questions you do:
http://www.chiefdelphi.com/forums/sh...&highlight=WCD
All in all, WCDs are lighter, allow for direct drive (more efficient), and the wheels a bit farther out for better turning. 6WD vs. 8WD is mainly based off of whether or not the robot has to traverse an object (climbing over the bumps in '12 and '10). 8WD also allows a smaller wheelbase, so that a robot can be more maneuverable, but the turning difference is often nothing a 6WD can't do, and the extra weight isn't worth the little bit of turning help on a flat field.
Unread 29-08-2012, 20:22
UAH Class of 2019
Rookie Year: 2010
Re: WCD vs Standard
Thank for that Andrew, some of those links will be helpful, but as for the 6 vs 8 wd, I phrased the question poorly, that is not what I am looking for. The standard vs. WCD ones are useful though!
Thanks!
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
Rookie Year: 2010
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: WCD vs Standard
SuperNerd's last link is probably what you are looking for (If I am reading your question right, you want to know the pros and cons of a WCD vs a non WC 6WD, not 6wd vs 8wd).
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 29-08-2012, 21:07
UAH Class of 2019
Rookie Year: 2010
Re: WCD vs Standard
Okay, so in the 4th link, I saw that WCD's use a live axle, vs. a Standard using a dead axle.
First off, could some elaborate on the difference between the two? I found the posts kind of confusing as to the difference (the live axle is spun by chain or gears or motor while dead axle is just sitting there, not powered?)
Next: Why would you choose a live axle over a dead axle, if the center wheel is lowered, thus making your robot rock between the front and back wheels? It seems that live axles (if I have their definition correct) would make the 6 wheeled work like a 4 wheeled when it turns, porblematic. But, when observing many WCD's, I do not see slick wheels or omniwheels to offset the traction/turning problems associated with a 4 wheeled.
Unread 29-08-2012, 21:15
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: WCD vs Standard
To my understanding, A live axle is one that supports part of the weight of a robot and drives the wheel(s) connected to it. A dead axle is one that carries part of the weight of a robot but does not drive the wheel(s). The wheel(s) rotate on the end of the dead axle.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 02-10-2012, 00:19
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: WCD vs Standard
Live axle = Axle turns, wheel is keyed to the axle.
Dead axle = Axle is fixed, wheel turns on the axle.
Unread 11-10-2012, 21:00
UAH Class of 2019
Rookie Year: 2010
Re: WCD vs Standard
So, doing more research on CD, I have come across bearing mounts called "Sliding Bearing Mounts". What are these exactly. It seems as if they are used for chain tightening, but I have no details about how they do this.
Unread 11-10-2012, 21:58
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Re: WCD vs Standard
Many teams build bearing blocks for their drive train which hold the bearing and axle. This bearing block can slide forward and backward in the frame (moving the wheel with it) in order to adjust chain or belt tension.
Unfortunately, 254's website is under construction, so I can't pull up any of the great pics I know they had there. I'm sure someone else here can dig up some instructive photos.
Unread 11-10-2012, 23:02
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: WCD vs Standard
It's interesting to hear so many people say that canilevered, direct driven systems are the lightest and best when some of the most successful teams in the world do neither of those things (most notably 67 and 1114).
I know Jim Z has done annalysis on 254, 1114, and 67's frames. I *think* 1114's frame was lighter than 254's by about two pounds.
We used .06 sheet metal this year and will probably go down to .05 sheet metal next year. I am pretty sure that our frame weight beats out 254's by a pound or two. What get's 254's weight so far down is there use of tiny wheels which takes weight out of both their gearboxes (which are custom and very light) and wheels (also custom and very light). Direct diving helps too I'm sure.
Perhaps, some 254 people could chime in and correct me here if I'm wrong on any of these points?
In any case, I'm just stirring the pot.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 11-10-2012, 23:09
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: WCD vs Standard
For the best example of a well executed sliding bearing block I would strongly suggest downloading some of 973's CAD models.
Unread 12-10-2012, 00:18
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: WCD vs Standard
I can't find a good picture of the bearing blocks themselves, but here's a shot of the rectangular holes in the frame where they go. You might get a better idea from browsing the rest of the 2012 build season album. Basically, there are two halves that come in from either side of the rail and fit inside each other, each having a bearing pressed into it. Long bolts through the rail are used to hold the two halves together, and there's a cam mounted to the rail that is torqued once the chain is installed to push the block which tensions the chain.
I wouldn't say that weight is the top factor in 254's choice of using a cantilevered drive year after year. It probably only comes in fourth after ease of maintenance, robustness, and aesthetics (you wouldn't believe how many design decisions come down to aesthetics).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
  #15   Spotlight this post!
Unread 11-10-2012, 22:03
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Rookie Year: 2011
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: WCD vs Standard
The "Sliding Bearing Mounts" are blocks that house the bearings for the live axle and they slide in slots in the frame. This allows you to move the axles slightly further appart tensioning the chain.
