Go to Post I, being a Trekky myself, will really enjoy a Star Trek themed game if it turns out to be that. I will not enjoy programming the alcubierre warp drive. :D - AveryLevin. [more]
Unread 02-09-2012, 14:26
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
pic: FRC488 First Sheet Metal Drive
Unread 02-09-2012, 14:27
Re: pic: FRC488 First Sheet Metal Drive
What gauge sheet is that? Looks slightly thinner than .090" to me. Is that a custom shifter or SS internals?
Looks great as usual, and super light!
Unread 02-09-2012, 14:32
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
I believe it's .090, but I am not certain. Those are regular super shifters with the black housing replaced by spacers; they're just bolted onto the side rails.
It's 34 lbs., but there are lots of places to take out some more weight. A lot of the webbing is thicker than it needs to be, but those are lessons that can come later. I was excited to see that all of the parts fit together in the first place. He did a MUCH better job with this than I did the first time I had to design a drive.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 04-09-2012, 10:06
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Looks very good!
You should look into getting rivets with the correct grip range, the ones you're using appear to be a biiiiit too long.
-John
Unread 04-09-2012, 11:03
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Very cool!
What is the spacing you chose for the standard mounting holes?
Have you considered using 0.063" if you have access to it?
Unread 04-09-2012, 11:53
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Looks great.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 04-09-2012, 18:22
Rahul Bhardwaj's Avatar
Rahul Bhardwaj Rahul Bhardwaj is offline
FRC #0488 (Xbot)
Team Role: Driver
Rookie Year: 2007
Rahul Bhardwaj is an unknown quantity at this point
THANKS! It's actually .0625'' aluminum The grip range is off by quite a bit since someone at our hardware store grabbed from the wrong bin (to be fair the one we ordered was longer than we needed anyway) but we decided to just go with it.
Rahul Bhardwaj
Team Xbot 488
Unread 04-09-2012, 19:30
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Definitely would be a good idea to make the spacing between the cut outs smaller, for reference I usually do 0.75" spacing, but now for parts of the plate that have nothing mounted on it I am most likely going to do 0.5".
I'm not sure why, but I always seem to make the chassis plates higher than the wheels, just to enclose them, I kinda like that it wasn't done here, a lot of weight was saved there, maybe I will do the same next time.
This also looks like a smaller wheel, I think 6" (if those are 8inch wheels that I'm looking at) could also work on this chassis. Not sure If that was planned for them to be interchangeable? But If it is interchangeable (even if it wasn't designed to), and you seem to have a hard time turning sometimes, you could increase the torque by putting smaller wheels on there.
Oh MY! Is that a designed battery box I see there!! WOW! Thats Luxury right there... Prop's to the student for remembering to design that in. After designing our whole robot myself this year, and the off season chassis, that's the thing I forgot Both times...
Over All Great chassis, hope that students knows how well of a job he/she did
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 05-09-2012, 02:42
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Just wanted to say this drive train looks fantastic, and has inspired me to finally start work on another concept of mine!
Thanks!
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 05-09-2012, 07:37
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
In my opinion, the most important part of the original post is this,
"We've been working with a new sponsor over the summer that brings sheet metal fabrication resources to our team."- Madison
This is a prime example of how to build team strength.
New Sponsor
working over the summer
new resource to the team
They may or may not be asking for money of the sponsor, but instead they have found something that might be more important. During the summer, they are working out the file transfer and formatting. They are getting a feel for the quality of work the suppplier can offer. They are also working on building a new line of communication. Many of us wait until the stresses of build season to try this out. It is easy then to allow those stresses to turn into pointing fingers rather than working through communication or timing issues.
Bravo 488 on a great project. Most of us could replace "sheet metal" with plastic molding, or shaft turning, or CNC bracket or ...
Unread 05-09-2012, 07:40
Thanks!
- Andrew
Oh god. You DON'T Need to design ANOTHER Chassis.
2013-Present
2010-2013
Unread 05-09-2012, 17:45
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Great work Madison!!
Are you able to bend the aluminum or are you attaching the flat pieces using angle between them?
Our chassis is built very similarly utilizing angle aluminum and a jig one of our mentors came up with to hold the pieces rigidly at 90 degrees...pretty slick
congrats to the designer and fabricators!!
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 05-09-2012, 18:31
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
The parts are were all bent on CNC breaks at the sponsor's shop. When the parts come in, we just rivet it together and it's good to go.
--Madison--
Unread 06-09-2012, 00:06
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
This is gorgeous. Can I have one?
Congrats on the new connections and having the opportunity to "work out the bugs" before you put one of these bad boys on the field.
Definitely looking forward to see what comes of this in a few months.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
