Go to Post All screws are not created equal. - Al Skierkiewicz [more]
Unread 08-09-2012, 13:59
Ravage457's Avatar
Ravage457 Ravage457 is offline
Ravage457
AKA: Jesus Jurado
FRC #0457 (Grease Monkeys)
Team Role: Coach
Ravage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to behold
Andy Mark Supershifter with Pneumatic shifters
Hello Chief Delphi Community
Our team has been using the Andy Mark Supershifter with servo shifter, but now i want to make the transition to pneumatic shifters.
Now i was wondering what are the pros and cons to going with this setup, besides the fact of being able to shift faster and the possibilty of busting the pin or screw near the dog gear
I greatly appreciate the input from the FRC/CD community
FRC Team 457 "04-"05,"07-"08,"11-Present
Lead Drive Train Mentor/Drive Team Head Coach
2014 Dallas Regional Winners:#1 Alliance-Captain: 148, 1st:359, 2nd:457
2013 Hub City Off-Season Event Winner:#1 Alliance- Captain: 457, 1st:3366, 2nd:1817
2012 Alamo Regional Winner:#3 Alliance- Captain:231, 1st:1477, 2nd:457
2012 Ozark Mountain Brawl Winners:#8 Alliance - Captain:1986, 1st:1987, 2nd: 457
2012 Texas Robot Roundup Winners:#1 Alliance- Captain:118, 1st:624, 2nd:457, Backup:4332
Unread 08-09-2012, 14:44
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Andy Mark Supershifter with Pneumatic shifters
Hey Grease Monkeys....judging from the TRR results, I guess you got that chain fixed!
Moving to pneumatic shifting is a change I would encourage for you. Obviously their is a small cost in weight and complexity with a new valve, cylinders, and lines, but the improved responsiveness and reliability is worth it. Regarding the risk of breaking the dog pin/screw I would make two suggestions. If you have dogs with screws, convert them to pins by drilling out the dog and shaft, and use a mil. spec. roll pin. The threads on the screws simply provide a fracture point that will fail eventually. As for the shock induced by air shifting, minimize it by adding speed controls to the cylinders (both directions.) They can be adjusted to eliminate the harsh hammer while still giving quick responsive shifting. A regulator could be used instead to reduce the pressure of the shifting air, but this reduces the reliability of both the valve operation and the shifting. Better to soften the motion with speed control and still maintain reliable force.
Unread 08-09-2012, 15:06
Ravage457's Avatar
Ravage457
AKA: Jesus Jurado
Team Role: Coach
Yes we did, and thank you Jspatz1, Team 1986, and 1987 for inviting us into your alliance at Ozark Moutain Brawl
would that roll pin help in preventing it from failing or would i have to replace it after a certain amount matches, i had read a post that here on chief delphi say that i should let the cylinder float on the bracket by not tightening the nut all the way and apply lock tie to keep it from coming undone, this allow the cylinder to adjust to shifter in case it not actaully center
this is uncharted territory for me especially, i appraicate all the help and advise that I can get
Unread 08-09-2012, 17:14
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
In my opinion yes, the roll pin will be much tougher than the screw and is the reason for dong it. Roll pins are compliant by their nature and built for shear loads. Cap scews are hardened and brittle by comparison and as mentioned the threads provide a stress concentration point for it to fracture. As long as you keep a punch and pin on hand to replace them if needed, I think the pins can be left in indefinitely. We have two that have been through two years service with no problem.
The suggestion to leave the cylinder nut loose is exactly right. The AMshifter asembly is not always perfectly alligned and any tightened misallignment will cause it to bind. We had a shifter assembly fail at champs once due to this binding. The pneumatic force on the shuttle is enough to damage itself if it binds. Rather than Loctite, we add a tapped setscrew hole to the cylinder nut, and lock it in a loose position with a setscrew.
Unread 08-09-2012, 18:28
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Instead of pneumatics piston perhaps you can try a solenoid?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 08-09-2012, 19:07
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
This is what we have been thinking of doing for the past year. Though this year we just locked our Gen-2 Transmission into low gear, because we didn't need high speed.
Has anybody had any experience using Solenoid's on their transmissions?? I think it would be a lot better especially for weight and speed of changing gears.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 08-09-2012, 19:47
Ravage457's Avatar
Ravage457
AKA: Jesus Jurado
Team Role: Coach
Ok, now the roll pin,can I get those at any hardware store, I would have to use a 3/32 drill bit to drill it out?
Unread 08-09-2012, 20:31
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
Yes you could get them at the hardware store, but probably not mil. spec. grade which would be significantly stronger than the commodity grade you will find at the store. It would be worth ordering several from McMasterCarr you would have them in 2-3 days. I believe AM used an extra-strength grade when they were using them.
Yes a standard fractional drill will work, the pin is slightly oversize and made to flex smaller when driven into a nominal size hole.
I would think there is very little experience out there with solenoids on AM shifters since this was the first year solenod actuators were allowed. It would take a substantial solenoid to approach the force of a 1/2" air cylinder, and the size/power that is allowed is limited. To get push and pull motion you would need a push-pull solenod, or two solenods, or would have to combine it with a spring return which would increase the size needed. One would have to look at what power is allowed and see how the pull force could compare to air. You would probably need a contiuous duty type for long periods of being energized, which means less pull force for a given size. Getting to a force comparable to air would likely get pretty heavy.
Unread 08-09-2012, 21:57
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Well for a 20PSI 1/2 inch cylinder you would get about 4.5 lbs. Here's a random solenoid close to spec that is about 2.2 lb push, 6.6 lb pull. Could probably alter the spring to even out the force?
Kevin Li
596 - Sciclones
Unread 08-09-2012, 22:30
Ravage457's Avatar
Ravage457
AKA: Jesus Jurado
Team Role: Coach
Thank you jspatz1 I'm gonna try this out by getting my own super shifter and try this set up out, and teach the team how to do it, I just hope I do it right
What is this solenoid shifter? And what advantages does this setup have, I saw the link. How does it work?
Unread 08-09-2012, 22:36
Imaginary Friend
AKA: Kevin Li
Team Role: Student
If you can use a solenoid there is a substantial weight and space savings by using a solenoid to do the push/pull action you need only the solenoid itself, the relay or solenoid module to drive it. The solenoid works when a current is driven through it, a EM field pushes the actuator.
With a pneumatic system you would need the storage tank, gauges, valves, regulators etc.
Kevin Li
596 - Sciclones
Unread 09-09-2012, 01:18
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
This solenoid is one-directional, push only. The spring return is only minimal to return the armature to the retracted position when de-energized. It is also intermitant duty, which means it can be energized no more than 50% of the time without overheating. A shifting actuator must maintain force in either direction at all times. This is one reason an air cylinder is well suited to the job. A continuous duty solenoid of this same wattage would have about 1/3 the force.
Unread 08-09-2012, 23:40
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
We used AndyMark Supershifters with pneumatic shifters on our 2012 robot Thermite. Seeing as i'm controls captain, I come from a different perspective. The code was incredibly simple and we used the trigger of the joystick to quickly shift back and forth between gears. Seeing as we already had the compressor on board for other elements of the robot, weight was really the concern for the pneumatics element.
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 09-09-2012, 00:30
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We used servos this year, and it was fine (once we calibrated them right).
I set it up with an Upshift and Downshift button (btns Right and Down respectively on a Logitech DualAction, yes those are face buttons), which then set the input state (high,low), which drove a state-machine through four possible servo positions (high,low,high-peak,low-peak), and that state would index a table to find the servo pwm values. It would peak and hold the servo, forcing it into gear then backing off to prevent servo burnout (we did burn out a pair of servos during the build season). I believe we were peaking for around 5 seconds.
Before doing peak and hold, we calibrated the high and low servo positions to the optimal steady-state position. The shift force immediately after requesting a shift was quite low, so I would have to jiggle the throttle stick to get both sides to shift. With the peak and hold, it usually shifted very quickly. We found that we rarely shifted, so it really didn't matter.
During autonomous, the script engine could directly set the input state and the peak and hold state machine would run. We ran autonomous in high gear, it was fast.
All of that said, we shifted pneumatically in 2011 and 2010 with no issues. We used the AM standard piston in 2010 and shifted at 60psi, and used a similar spec pancake-stype piston in 2011, also at 60psi. We heard about the breaking screws in 2011 and replaced the screw with a roll pin at CMP. I believe our 2010 robot already had roll pins. During the 2011 season, I also worked on an automatic trans shifting algorithm, and it always assumed it could shift with little lag during shifting (including during acceleration).
Kettering Motorsports
