Go to Post kids under stress poor eating habits even worse food walking around a cold ice rink all day contact with 100s of kids from all over the world = robo flu. Maybe the virus going around is the real "FIRST fever" - Wayne C. [more]
Unread 08-09-2012, 17:23
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
pic: First attempt at Sheet Metal Chasis
Unread 08-09-2012, 17:28
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: First attempt at Sheet Metal Chasis
1.) Do you know how you will mount the gear boxes or transmissions?
2.) Do you plan on tensioning the chain? If so how?
3.) how do you plan to assemble the pieces? welds? rivets? screw?
4.) I like how you planned out the chain paths
5.) You might be able to make the side plates shorter to lose weight.
But looking good so far keep on working, this is how you truly get good at CAD!!
Unread 08-09-2012, 19:14
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Exactly what I was thinking. I've done 10 ish Chassis' now and I keep improving each time.
You may want to change your lightening holes. You can make triangle instead, they make your chassis as strong as it could be. With rectangle cut outs you will have more bowing.
Definitely cut down on the bottom off the chassis. its just extra weight. I usually have the axles 1" from the bottom of the chassis. still strong, and lose that extra and useless material.
If you are gonna desgn something, make sure you have all your parts needed for it. You are gonna want to put transmissions in there. you will most likely not have enough material to mount them after. Transmission Supports/cross members are a good idea too.
Mka esure you design to your resources. Even If you don't want to build this you should practice building to your resources. Like do you have a sponsors or something to cut the material. And a way to bend it. You should ask yourself these questions while designing.
Good Luck! keep practicing!
Sorry if there is bad grammer. wrote this in a rush.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 08-09-2012, 21:22
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Do those wheels even touch the ground? The gussets suggest that the answer is no, and it would be helpful if they did.
Unread 08-09-2012, 21:40
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
Looks good for a first time, however as others have mentioned you need space for a transmission in there, in our sheetmetal chassis we made mounting holes for the gearbox between the center wheel and the end and powered it via 35 roller chain.
Also be sure to leave sufficient ground clearance, many flat field frc games...aren't (bumps around towers in 2011, etc).
What thickness, material and bend radius are you using?
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 09-09-2012, 01:39
tickspe15's Avatar
Purdue University
Thanks for all the input...I'm am working on the gear box mounting, and thr wheels do touch the ground but with very little clarence. I am using 1/8 in aluminum and a 2mm radius.
Unread 09-09-2012, 01:49
tickspe15's Avatar
Purdue University
1/8 inch almuminum with a 2mm bend radius
Unread 09-09-2012, 01:48
tickspe15's Avatar
Purdue University
I will change the lightening holes to triangles and cut down on the bottom thanks for the insight
Unread 09-09-2012, 01:46
tickspe15's Avatar
Purdue University
1/2)not sure about mounting gear boxes yet or chain tensioning
3)will be assembled with rivets
