Go to Post And I think the poll needs another option: WILL be under weight ... eventually ... just get me a drill. :D - Franchesca [more]
Unread 10-09-2012, 10:33
1296MTRHS 1296MTRHS is offline
FRC #1296
1296MTRHS is an unknown quantity at this point
D-Link 1522 Issue Need Help Please
The team is trying to setup our router for wireless control. We goto the D-Link page with the address 192.168.0.50 to change the settings, we get all the way to setting the Network Settings and saving it, then the page crashes it happens everytime. What are we doing wrong?
Unread 10-09-2012, 10:55
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: D-Link 1522 Issue Need Help Please
If you're having problems, you may want to switch to using Internet Explorer while changing these settings.
Also, remember that when you change the device's IP address and save those settings, you will need to put that new address into the browser in order to get back to the settings page.
If these don't work, some clarification on exactly what you see when you say the page crashes would be helpful.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 10-09-2012, 11:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You will also have to change the computer's network settings in order to be compatible with the new address. To reach the router at 10.12.96.1, your computer should be at 10.12.96.6 (the last number can vary, based on whether you're using the Driver Station computer or not).
