Suggestion on What to use on battery Terminals
Hello Chief Delphi community
I wanted to ask, what does everyone use to protect the terminals on the battery, do some use electrical tape or shrink wrap? What do you, ladies and gentleman use on your battery terminal to protect or cover them? |
Re: Suggestion on What to use on battery Terminals
Terminals on the batteries need to be checked often to make sure that they are tight. That is why we use electrical tape instead of shrink wrap.
For our battery terminals, we use locking nuts to help ensure they won't come loose, and some heat shrink. These get checked multiple times per season (beginning of the season and before every competition) to make sure they haven't come loose. If any do (we've only had a couple that have over the past 6 years), we cut away the heat shrink and completely redo the connection (with new heat shrink as well!).
Our feeling is that heat shrink is slightly safer, as it's harder to accidentally remove than electrical tape. That said, there's nothing wrong with using electrical tape, so long as you ensure everything is covered and make sure the tape doesn't start pulling up! |
Before using heatshrink we assemble the terminals in a special way. The use of an external tooth star washer between the terminals and the addition of locking hardware will insure that the termination will never come loose. If the terminals cannot move, the hardware (even locking hardware) will not come loose. I am a big fan of keps nuts (lock washer is integrated in the nut) and battery terminals are only one place they are useful. They are available from McMaster.
PAR - The nut and bolt aren't involved all that much in the electrical pathway. The electricity will primarily flow from the battery terminal through the lug terminal on the end of the battery connector. This is due largely to the large surface area connection between the two, which makes it a much, much more efficient conductor than going "out of your way" to travel from the battery terminal, through the head of the bolt, down the bolt, into the nut, and finally into the terminal on the end of the battery connector.
True, any time you have conductive materials attached together, all of the materials involved will conduct some electricity. But in this case, it's not enough to make it noticeable. Essentially, you have a current divider circuit, with the two sides of the circuit having significantly different resistances. Play around with that, and see how changing each side of the circuit can change the overall current through the circuit. |
Alan,
While it might add a slight series resistance, the teeth of the star washer bite through any surface crud and oxidation on the lead battery terminal and when tight produce more contact surface than the terminal. AS the hardware tightens on the normal terminal it deforms and produces a cup shape. The ability to keep the terminals from moving is the distinct improvement here. We have batteries labeled as far back 2006 that we use for practice that have no issues with loose terminals. |
Is their a specific size of heat shrink that has to be used?
Jesus,
It depends on the size of the terminal you are trying to insulate. It will likely be somewhere between 1/2" and 1". |
#10
If you look at the specs for heat shrink, it'll specify an inside diameter both before and after shrinking. You'll want to get some that is big enough to fit over everything, including the nut and bolt, but that will shrink down to a snug fit without splitting. I've seen students use the wrong heat shrink a few times... it looks good, then they put the heat gun on it, and it splits because it tries to shrink too small for the wire it's around!
#11
1. Buy good heatshrink. The ES200 line from Tyco (http://www.strancoproducts.com/downl...ta%20Sheet.pdf) has an amazing 4:1 shrink ratio and is pretty rock solid 2. When cutting the HS from a longer length, make sure the cut is straight and contiguous. Any aberration along the cut will likely cause a tear. This commonly happens when cutting a larger diameter HS with a pair of side cutters, where you can't cut across the width with one full cut. We typically use a pair of stout scissors or, odd as it sounds, a heavy duty paper cutter (good for getting precise lengths). |
#13
Thanks again Chief Delphi Community for the advice and input, it greatly appreciated, as i have so much to learn |
#14
I use it all the time and reccomend it to you! ![]() |
