Go to Post Flash drive? I was thinking floppy disks... :ahh: . - MrForbes [more]
Unread 16-09-2012, 16:21
FTC-4077's Avatar
FTC-4077 FTC-4077 is offline
AKA: TomTom Fogwell
FTC #4077 (M.A.S.H)
Team Role: Driver
FTC-4077 is an unknown quantity at this point
[FTC]: How will you Score?
Since all we seem to be talking about recently are the specific elements and rules of the game, I was wondering what everyone's thoughts are on what they will use to score the rings.
Are you going to use a single arm with a wrist on the end? A cascade lift, scissor lift, etc. Didn't know if anyone had found a unique way to score these rings considering how small the gap is between the ring's inner diameter and the scoring post.
We are a veteran team based out of Chester Springs, Pennsylvania.
2011-2012: PA State FTC Champions, State Connect Award, World Championship Finalists
LIKE OUR FACEBOOK PAGE! Team MASH 4077!
Unread 16-09-2012, 16:30
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: How will you Score?
I can't compete so you'll never get to see my both, unless I post the CAD here. But I will have a cascading lift with a gripper on the end that grabs one tube. the lift can then pivot on an axis and score from both sides, lift from both sides and also pick up off ground on both sides.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 17-09-2012, 09:22
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
I'm not involved much this year since I'm busy being a college student at college. If I were playing I might stick with a short turreted arm mounted on the corner of the chassis to score on the bottom row and corner goals. It would be servo actuated and capable of detecting weighted rings. The rest of the robot would be dedicated to a lifter. The Main focus of the robot would be the arm, the lifter is there simply because the arm wouldn't take up that much space and extra points are extra points and shouldn't be ignored. The type of arm I would use would be a three d.o.f. arm with a shoulder and an elbow mounted on a turntable. I don't know what kind of grabber I would use, but it would ideally be able to pick up and drop rings easily so that it could locate and score weighted rings. Structurally I would likely use mostly Tetrix tubes for the arm with angle brackets and servo mounts connecting the sections. Positioning would be purely pre-set positions to reduce driver work load. Visible signals would alert the driver of possessed weighted tubes so he could move closer to the corner goal to score them. The lift would be as simple as possible, likely a ramp leading to a scissor-lift platform that gives an extra few inches to the lift.
To get the ring onto the scoring peg, I might use a pair of limit switches attached to v-shaped levers to auto-align, or I might use a secondary claw, a passive v-shaped guide, or a flexible funnel that would be placed over the peg and the ring would be slid over the wide end compressing it around the peg creating a smooth transition from bot to peg (but no so much as to grasp, grab, or grapple the peg.
