Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 17-09-2012, 17:16
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
"compiler" constants
New to Python. Have what I hope is a simple question.
I realize Python is interpreted, but I was wondering if there is something in Python equivalent to "compiler constants".
To illustrate with a very simple example, suppose I have a function:
Code:
def MyFunc(x)
    return a*x^2 + b*x + c
... and I want to pass this function as an argument to a library function which is expecting only one argument (i.e "x").
Can I assign constant values to "a" "b" and "c" and have the interpreter literally replace all occurrences with the numerical values?
Unread 17-09-2012, 18:41
Ether's Avatar
Rookie Year: 1969
Re: "compiler" constants
Originally Posted by Ether View Post
...............click for context^
Here is what I found, to my surprise:
I can simply assign values to variables a, b, and c:
a = 2
b = 3
c = 1
... and somehow when I pass MyFunc(x) to the library function as a parameter, it works.
It had not expected it to.
Does anybody know how this works "under the hood" ?
Unread 18-09-2012, 00:43
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
As you've found out, there are no such things as constants in Python.
There are other oddities that people used to other languages find weird at first. No such thing as private variables in a class or module. Just about everything happens to be a variable of some kind. No enums (though there are neat tricks to simulate enums).
For fun, you can also define functions inside other functions:
Code:
>>> def some_fn():
...     x = 1
...     def _some_other_fn():
...         print x
...     _some_other_fn()
>>> some_fn()
Functions can actually be treated like variables too.
Code:
>>> def fn():
...     pass
>>> x = fn
>>> x
<function fn at 0x7ffe4c917578>
>>> x.y = 1
>>> x
>>> x.y
But, to actually answer your question, this SO post has a reasonable set of answers about Python's scoping rules.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 18-09-2012, 08:11
Ether's Avatar
Rookie Year: 1969
You can do this in Delphi too. It can be a helpful way to organize code and make it more readable.
