Go to Post Look at 71's 'walking' bot from last year. One dosn't need wheels/track to move. All you need is an idea. - Jack [more]
Unread 19-09-2012, 21:48
sLombardo sLombardo is offline
sLombardo is an unknown quantity at this point
[FTC]: IR Sensors
Does anyone know exactly how accurate the IR Sensors from the HiTechnic website is? And what the range of the Sensor is?
Unread 20-09-2012, 01:17
Rainydaymaker's Avatar
Rainydaymaker Rainydaymaker is offline
AKA: Jim
FRC #1983 (Skunk Works)
Rainydaymaker is on a distinguished road
Re: [FTC]: IR Sensors
The IR seeker has about 30 degrees of spread for each value. It can detect a signal from across the FTC field.
Jim Smith
FLL Coach
FTC Coach 3721
FRC Mentor 1983
Unread 20-09-2012, 09:27
Flex..(Re-Flex)'s Avatar
Flex..(Re-Flex) Flex..(Re-Flex) is offline
AKA: Nathaniel Jefferson
FRC #2757 (Built and Dangerous(B.A.D))
Team Role: Leadership
Flex..(Re-Flex) is an unknown quantity at this point
The IR sensor's zones ranges decrease as you turn farther from the front of the sensor. You can actually increase the IR sensor's accuracy greatly by straddling two zones(like line following with a light sensor).
Unread 20-09-2012, 10:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Yep.
In 2010, one of our more brilliant programmers could detect the direction of the IR beacon to within a +/- 2-3 degree accuracy regardless of the starting orientation. I know his basic algorithm (took 2-3 seconds overall), but I do not know the implementation or the tweaking he did to get it so accurate. I'll also say that he put the sensor on a servo so he could accurately adjust the sensor's starting orientation relative to the robot every match (actual orientation determined during off-match calibrations).
Go here for a basic understanding of the sensor.
1.) Spin in place until the IR beacon is detected at direction 1 or 9 -- note the reading of the beacon and (if available) heading sensor. If the sensor is detected at the start, then go in either direction to the edge (either 1 or 9) and then turn back towards the beacon. The point of doing this is to calibrate the edge conditions.
2.) Keep spinning in the same direction, keeping track of the 'maximum' for all 5 registers of the center sectors (4-6).
3.) Once the IR beacon is lost, stop turning, then start turning back the other way.
4.) The basic way to get back to center is to continue turning until the center values match their maximum.
That year they could shoot a 3" diameter whiffle ball into a 12" hold that was 24" off the ground, even at a steep off-angle, in autonomous. Pretty nifty.
GitHub
Unread 25-09-2012, 09:17
Ok thank you!
