Thread Tools |
Rating:
Display Modes |
Re: Shop Tools, Hand Tools, HELP?
With any new tools, we will get experienced mentors or ask other teams to come out and teach us, or at least myself. It is my responsibility to see that all the tools are properly operated, so I will be willing to pass on the training. Having another student lose their fingers would be worse for me then losing one of my own! The only problem we have with Craigslist and classifieds is the ads go up quickly, and require items to be picked up, sometimes quite far away. With out limited number of mentors, we can't really go anywhere on short notice. Plus, it's easier to point at a new product for a sponsor to purchas. We do not know if they are willing to provide direct funding yet. Jackson and rondinol, good info. Will be kept in mind! Quote:
According to google maps, San Francisco State University is very close to your high school, as is the City College of San Francisco. Those two will probably end up being two of the best resources you could possible establish in terms of machining capabilities and mentoring. Both are within two miles of Lowell HS.
Be sure to check both out very soon. |
In principle I am against paying $600 for a sliding compound miter saw. It's just not that much more useful than a regular miter saw, for FRC purposes. If you were framing up a house every day of the year and required the versatility and the durability of a professional grade tool it would be the right choice...but that isn't what we're doing in FRC. I don't really see one as a replacement for a bandsaw or table saw. You can cut a 15"x15" square with a 12" sliding miter saw. I guess that's better than if it wasn't sliding, but it's nowhere near a real table saw and I'm not sure in what way it would be equivalent to a vertical bandsaw, as they are primarily used for contouring. You should be able to find a fairly decent vertical bandsaw for a couple hundred dollars. With good blades and proper care it should cut aluminum up to 1/4" thick with no problem (inevitably people will cut steel with it, or shove aluminum through at about a zillion miles an hour and ruin your brand new blades though). We use the clamp that came with the saw. We have a beat up folding table that we will often bolt the saw to and then wood screw down a stop to ensure repeatable length cuts for tubing that gets welded without being further processed on the mill. Otherwise we just use it on the ground. |
Just one other thing I just thought of...
do you have a local technical school near you? You might be able to partner with them and they might be willing to help you guys out with machining of parts and welding. This is where you might also find access to a nice printer or computers. F22Rapture bringing up community colleges made me think about it. |
There's a pretty nice 3d printer in our school's Engineering classroom...we've had Engineering students on the robot team for a few years...and we have yet to figure out a robot part that we could print with it. I would look at other things to spend money on.
It sounds like you need put in some "shop class" time before you get too far along buying tools. Knowing how to use them is vital. |
Saw this and had to comment: Skyhook's intake roller had a pair of hubs that came off a 3D printer, complete with the "standard" 6-hole bolt pattern. And the box containing Skyhook's IMU came off the same printer. And at that point, we'd had the printer about a month, maybe 2. When I was in college, we got some plugs for a robot's frame built on their high-quality one.
If you're stuck for space and/or cash, you might consider a combo mill/lathe/drill. It won't do any of these tasks as well as the individual tools might, and it's small (but so, relatively, are the robots), but it wouldn't take up too much space and would at least provide you these capabilities at a lower cost than the individual machines.
I think that there are other teams who use one of these as (one of?) their primary machine. A quick google search ("combo lathe mill") will show you a number. From what I've read, there's basically a price/quality relationship. The more you pay the better the tool, so, if you go this route, buy the best you can afford. |
#10
If you're looking for larger machines, try industrial auctions. We picked up a Bridgeport in good condition for ~$750 including vice and a set of R8 collets. Just watch your voltages as many industrial machines are 600V. To meet school regualtions, we have to install a magnetic swtich as well and fix up the guarding.
#11
A low cost metal bending brake plus an inexpensive shear would be worth considering if you have a table to mount them on. Bent sheet parts are useful in lots of places. You can get both at Harbor Freight for a combined $200.
#13
Agreed. A tool you don't know how to use is functionally useless.
#14
At best. Just as often it's a liability to your work or your safety.
#15
Many products from RIGID come with lifetime warranty on everything including batteries....
I'm not sure if this has been added but a good tap and die set is something great to have around |
