Go to Post Have I ever poked fun at you? OK, maybe Heidi. and JVN. And Dave Lavery. and Andy Baker. and .... all right, I guess I deserve it. - Gary Dillard [more]
Unread 09-10-2012, 12:46
kbocheltree kbocheltree is offline
FRC #4122
kbocheltree is an unknown quantity at this point
Unable to deploy over Ethernet using WindRiver C++
This is our second year and we are moving to C++. We are able to build our projects using WindRiver and have only been able to deploy them over wireless, ethernet will not allow use to deploy the code, it hangs on transferring the code and never starts. We can do everything using wireless, but as soon as we try using wired Ethernet, it won't deploy
In Ethernet (With wireless disabled)
1. We are using the static IP address
2. We can ping the cRIO over ethernet
3. We can see the communications to the remote cRIO in the WindRiver window
4. Firewall and Antivirus was turned off
Any other suggestions? Is there a good way to get a trace to see where it fails?
