#16
Re: Robotics Question of the Day!
... and "high gear" has a low gear ratio. That's probably where some of the confusion comes in. |
#17
How did the 2010 ranking system work?
#18
By losing the match, I might add. Props to them though, playing the metagame is just as important as playing the game.
#20
Discussing ranking systems is a really good idea. FIRST likes to switch them up and sometimes this will influence how you design your robot. A fun hypothetical might be: Originally matches were 1vs.1vs.1 Then FIRST improved to the 2vs.2 format. Then FIRST improved (by most folks opinion) to the 3 vs. 3 format. How would FIRST change if they went to 4vs.4? What would be the benefits and what would be the disadvantages to 4 vs. 4? |
#21
Q: How many speeds/gears are necessary for the XXXX game? Q: How many different ways could you pick up an innertube/basketball/other game piece? Q: Where is the most important part of the field for the robot? |
#22
Drivetrain, Drivetrain, Drivetrain, anything that makes the drivetrain legal (bumpers included), game object manipulation #1, game object manipulation #2, game object manipulation #3. The difference in the game object manipulators: #1 is acquisition, #2 is delivery, #3 is either anything internal to the robot or working with any stationary field element. The reason they're game object manipulators is that it's quite possible that they may be dealing with stuff other than game pieces, like mobile goals or bridges or hanging bars. |
#23
The reason I specified game object (NOT game piece) is that there are often multiple objects that it is helpful to interact with by using a specialized mechanism. Say, the bridge or the towers mentioned. All game pieces are game objects, but not all game objects are game pieces. I should also have mentioned that the #1, #2, and #3 designators can be shifted in priority--say, #3 comes first. (Though I don't suggest swapping #1 and #2; it's kind of hard to score a game object if you don't have one.) In actuality, endgame work could be as high as #1 (iff it's done only with a drivetrain, like the 2006 ramps) or #5 (if it needs a manipulator to do). |
#25
Lets keep the OP in mind guys..
#26
Apparently I started something here..
Revised list of important robot related functions assuming legality: 1. Drivetrain 2. Drivetrain! 3. Drivetrain!! 4. Picking up the game piece. 5. Drivetrain!!! 6. Processing the game piece.. 7. Drivetrain!!!! 8. Delivering the game piece... 9. Drivetrain!!!!! *4-10 Endgame (depending on game) Interestingly enough this follows gameplay rather closely.. Drive, pick up piece(s), drive while processing, score, repeat. Another fun question: -What are the three tightest constraints on the robot? (IMHO) 1. Money 2. Time 3. Weight However, this one is more up for argument. Regards, Bryan Last edited by BJC : 19-10-2012 at 22:00. |
#27
Q: Who should you not instantly blame for errors when they happen?
A: Programmers. It's good to break this stereotype sooner than later. Q: What must be worn at all times when working on the robot? A: Safeties, closed toed shoes, etc. Q: Where is the FIRST aid kit located? A: "answers will vary" Q: Where is the largest/smallest gauge wire used on the robot? A: "answers will vary" Q: When working with aluminum and nuts/bolts, how much should you tighten them? A: not too tight Q: Where is metric crescent wrench? A: I have no clue what you are talking about... Q: Should a chain be completely taut? A: No. Q: Should the robot frame have a charge? A: No. This can be prevented by isolating motors, and checking wires. Q: What is the best type of drivetrain/mechanism? A: The best one we can build w. our resources. Q: If the robot does not turn on, what is the first thing to do? A: Check the battery. Q: What is called when you lend a team some part at a competition? A: Gracious Professionalism |
#28
What is the large PDF that everyone is supposed to read called?
A: The Manual. Who needs to read the Manual at least once? A: Everybody. Twice or thrice is preferred, though. |
#29
Remember that {endgame} ⊂ #1 IFF endgame is done only with drivetrain functionality ⊂ standard movement. (The endgame may involve only the drivetrain, but well above and beyond standard movement.) From the perspective of the OP, these questions are important. One of the worst mistakes you can make early in the design strategy process is mis-prioritize or used overly-constrained verbiage (thereby constraining minds). Look at the teams that ignored the minibot or constrained themselves to hanging on the horizontal bar in Breakaway [not that that didn't work for some also]. Given that Ryan's looking for ways to get kids minds going and inspire them to want to try it, such an open-ended "what's a good structure for determining the top priorities of a FIRST robot" question is actually a pretty valuable discussion of the day. |
#30
Free clue for the still-confused: The "metric" refers to the scale on the jaws that lets you know what size nut or bolt head you're rounding off when you use it. |
