Go to Post I was proud that there was no whining, no finger pointing and no complaining. - Vikesrock [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 28-10-2012, 12:12
Trish Fisher Trish Fisher is offline
FRC #2240 (Brute Force)
Rookie Year: 2012
Trish Fisher is an unknown quantity at this point
Re: 80/20 Inc.
Thank you everyone for your replies!!!
The FIRST Community is the best!
Trish
Parent Volunteer and FRC2240 Team Mgr.
Unread 18-10-2012, 09:09
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: 80/20 Inc.
I've never used 8020 on a competition robot (always been a weight concern) I have used it professionally though.
I think it really does get you "80% of what you want, for 20% of the effort."
As a side note: we've never had an issue with the kit-bot frame never being stiff enough or strong enough. Though we always mount a board in the center of the frame (plywood or composite) to mount electronics and stiffen the frame. Welding the kit frame drops about 3lbs in fasteners and brackets.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 18-10-2012, 09:19
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Re: 80/20 Inc.
Originally Posted by Jon Stratis View Post
Last year, I saw team with a bunch of 80/20 on their robot come in 30+ lbs over the weight limit at a pre-ship scrimmage... I believe they made the limit just by replacing that with simple 1" square stock.
Regarding the weight issue, be careful how you replace 80/20. The common (and lightest) 1" square profile (1010), is .5097lb/ft. Compare to different 6061-T6 Al profiles.
lb/ft............Extrusion Profile..............................Length req. for -30lbs
0.513.........1" (1/8") square tube......................N/A
0.5097......80/20 1010 Profile.......................N/A
0.410.........1" (1/8") channel.............................301ft
0.285.........1" (1/16") square tube....................134ft
0.280.........1" (1/8") angle......................,.........131ft
Values vary slightly, primarily depending on the exact extrusion spec (AA, AS, etc).
Depending on your application, you'll likely be able to get away with lighter-weight extrusions in many situations (U-channel is usually* a reasonable structural substitute), but it's not as big a difference as many think.
*As in not always.
