Go to Post At first, "water game" was funny. Then it went to silly. Now it's just dumb. Not to mention unrealistic for FIRST. - EricH [more]
Unread 21-10-2012, 00:30
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Team 488 using Kinect for autonomous navigation
http://www.youtube.com/watch?v=yD5toEIT-DU
In the off-season, intrepid programmers from team 488 have been working on some fun Kinect projects. Our primary goal - to have an FRC robot navigate a unknown (and potentially changing) environment with no prior knowledge of that environment.
Our setup/process is as follows:
-Kinect running from the robot power supply
-Kinect plugged into a Laptop running RoboRealm
-Roborealm processes the depth image from the kinect and looks for obstacles
-LabVIEW program running on the cRIO queries the RoboRealm server for obstacles
-LabVIEW program determines the importance of the obstacles, based on their distance angle
-LabVIEW program sums all the forces (including the robot's desire to advance) and advances/turns as necessary to progress
In the future, we want to make a number of improvements:
-Replace the laptop with a small form factor (on-board) computer
-Integrate into a field-oriented system to give the robot higher-level goals (going to a specific point, instead of just advancing)
The Kinect has a lot of potential!
Unread 22-10-2012, 18:38
Billfred's Avatar
Billfred Billfred is offline
Re: Team 488 using Kinect for autonomous navigation
John,
This is pretty awesome stuff! Especially with a goal point, I could see a number of past games where this system could be highly valuable. Keep it up.
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 22-10-2012, 19:45
FRC #0488
Yeah, we're hoping the time investment will pay off next season... but it does require a number of things (an onboard computer, good line of sight for the Kinect) that are expensive from both a cost and design perspective.
We hope to have a white paper and some libraries available for consumption before the end of the year, in case anybody else is interested in going down this path.
Overall, it has been a fun project. Has anybody else been playing around with an onboard Kinect in the offseason?
Unread 22-10-2012, 20:22
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Very cool. The Kinect is an amazingly effective sensor for mobile robots, especially considering its cost.
Now put a A*/D* path planner on there and go to town
Unread 22-10-2012, 23:53
Meshbeard's Avatar
Meshbeard Meshbeard is offline
Previously of 422
AKA: Jonas
FRC #0190 (190)
Meshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to all
Do you think the video processing could be done by a Raspberry Pi, or is it too intensive? If it's not, you should look into some Pis.
http://www.raspberrypi.org/faqs
Team 422 is planning on doing some sort of image processing onboard the robot next year with a Raspberry Pi. Whether that will be Kinect data or just regular video data has yet to be decided.
Unread 23-10-2012, 15:09
Paul 2912 Paul 2912 is offline
FRC #2912
Paul 2912 is an unknown quantity at this point
This may be a simple question, but I'm not able to pull up my program from 2012 Robot Rumble. When I try to open the file it says "Warning - has been deleted, renamed or moved on disk". I'm not sure how the associations with all the files got lost but I'm hoping there’s a way to restore them. There is of course the program that is still working in the CRIO on the robot, if there is a way to pull that back into the laptop?
Thanks
