Go to Post As a rookie team member at my first event, i had a great time, the little glitches meaning nothing. - Gluedtothefloor [more]
Unread 22-10-2012, 17:31
Fuzzball27's Avatar
Fuzzball27 Fuzzball27 is offline
AKA: Dan
FRC #4218 (Navibots)
Rookie Year: 2011
Fuzzball27 is a jewel in the roughFuzzball27 is a jewel in the roughFuzzball27 is a jewel in the rough
CRIO file extension
What type of file does the CRIO run? Is it .exe?
If you need clarification of my question: the Lego NXT program extension is .rxe what is the equivalent for the CRIO?
-->Fuzzball27-->
Unread 22-10-2012, 18:07
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2010
CodeYeti is an unknown quantity at this point
Re: CRIO file extension
I think you will find a lot of the information that you've been asking about recently here. But, to answer your question directly...
Code:
FRC_UserProgram.out
Is the name of the binary expected by the cRIO imaged with the FRC image. The cRIO runs VxWorks. That could also help your investigations.
Unread 22-10-2012, 18:26
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
It runs whatever language you deploy to it. .rxe is the extension for the Mindstorms variant of Labview, which isn't necessarily dependent on the platform it's running on. Java for example compiles to bytecode (which I think, though I'm not sure, has a .class extension) which can run on pretty much any hardware for which a Java VM is available and supports the functions of the program.
An example of an extension that *is* platform dependent would be .exe, which is only understood by Microsoft Windows, unless you were using something like Linux + WINE to run them.
TL;DR there is no "extension for the cRIO," it's going to depend on which language you're using.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 22-10-2012, 20:30
I think there are couple answers to your question. The LabVIEW build specification constructs a file named startup.rtexe. This is what NI uses on VXWorks for the exe format.
Another answer would be the .out extension. This is the basic code/library/task extension, and if some code loads it, it can begin running. This is how the NI loader loads the .rtexe.
Greg McKaskle
Unread 22-10-2012, 22:35
Fuzzball27's Avatar
AKA: Dan
Rookie Year: 2011
Ok what is the extension if I use WindRiver (c++)?
-->Fuzzball27-->
Unread 23-10-2012, 21:39
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
.out
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
