Go to Post So we are able to run a very competitive and active robotics program. Sustainability, alas, is a month-to-month issue for us and is dictated by the space situation. This is okay today. Tomorrow could be different. We live like this. - Clem1640 [more]
Unread 23-10-2012, 03:43
Miscar1574 Miscar1574 is offline
FRC #1574
Miscar1574 is an unknown quantity at this point
FRC LabVIEW Kinect problems
We are trying to install the Kinect Drivers and program the kinect with LabVIEW But we are Getting this error: "Error 7 occurred at Call Library Function Node in WPI_DriverStationGet Kinect Vertices.vi->Untitled 1" every time we deploy a program that includes a VI related to the kinect. we tried reinstalling the kinect drivers and the FRC kinect server and we still encounter the same problem. please help
Unread 23-10-2012, 15:10
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: FRC LabVIEW Kinect problems
Error 7 usually means that the library file it's looking for is missing. Perhaps your LabVIEW runtime didn't get installed properly? Try rerunning the Driver Station setup from the original USB flash drive.
Unread 23-10-2012, 15:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It sounds like someone edited one of the kinect VIs (Get Kinect Vertices.vi) and accidentally added a new VI (Untitled 1). Since you say that this happens when you deploy to the robot, I suspect the problem is in the LabVIEW library. I would recommend reinstalling the LabVIEW update.
