Go to Post Looks like we will be building a wood robot :) - IndySam [more]
Unread 24-10-2012, 09:33
cwang30 cwang30 is offline
FRC #4573
cwang30 is an unknown quantity at this point
LabView Installation Error
Hi,
Here is the rookie team again. We do not have the USB stick from 2012 KOP, instead other team burned us a DVD for LV FRC 2012.
I used the DVD installed LV 2012 in one lap top win7 (64 bit) without any problem. But when I try to use the same DVD to install in other XP (32 bit) and getting the error:
NI LabVIEW for FRC 2012
Error: Windows SDK functin returned an error. (Error code -12)
Error Details:
Windows function StreamIn returned an error. Error code: 4294967280
End Error Report
Tried install in different PCs, same error. Any ideas?
Unread 24-10-2012, 11:03
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Re: LabView Installation Error
Try the advice posted here: http://digital.ni.com/public.nsf/all...25766B005859D2
It also looks like this error might be caused by a missing dependency. Make sure your Windows is fully updated (www.windowsupdate.com)
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 24-10-2012, 11:21
FRC #4573
I did try the solution but no luck. I called NI support, the would guess the installation files are corrupted. I tested by re-install it in my working PC (it was installed successfully before), then I got the same error message.
Anyone have the original software I can try? (No need for license key, just the installation software).
Thanks - Charlie
Unread 25-10-2012, 22:22
FRC #4573
Unhappy Re: LabView Installation Error
No one want to help.
