Re: #25 Chain Drive Experience ???
Tom Did you order extras? I have been working with small teams so we have been ordering just enough + 1 spare so when both sprockets come in with notches in them, we are stuck. I will consider different sources in the future but the steel ones from Grainger get pretty heavy when the tooth count gets high. Does anyone have any suggestions for sources of better quality #25 sprockets other than AM? Nick and Rob It was great to see your most eleagant robot in the flesh in St. Louis and to be able to speak to some of your students. It was one of our favorites this year. I think your school is just a few km of where we used to live in TO. See you next time. Phil |
But for now, you could send them back? We've called AM a few times for random misc. problems, they've been so kind to ship out replacements ASAP. Instead of buying them you could router/laser/waterjet them from .118 or .125 plate and then chamfer them yourself? Do you have access to a CNC machine or do you have sponsors that own them? -RC |
In my experience, even #25 chain can be run fairly misaligned under some circumstances. Last year, we ran our practice bot with one sprocket on backwards. Their was not much load (it was an intake being powered), and the misalignment was fairly substantial, approximately 1/4" over about a 4" run. When we realized that it had accidentally been installed incorrectly, it had been running that way for almost a week with no problems.
I'm sure that high tension, high load drive chains are much more given to throwing with misalignment, but don't get scared away from a lighter solution. To add one more story to the others in this thread, we've run #25 drive chains for at least 4 years with absolutely no problems with misalignment. We did experience a bit of stretch, but our tensioners have solved that problem very handily. |
My concern with exchanging the sprockets is that it would just be a waste of time. Since both sprockets had the same "notch" in them, this is indicative of the design or the CNC programming of the sprocket so any replacements would also likely have the same flaw. Unfortunately, we do not have access to a CNC nor do we currently have sponsors who can make one available to us. What alternative power transmission method is recommended at these high speeds? Belts? Gears? Thanks. Phil |
Could you post a picture of what you're talking about? An error on two sprockets doesn't necessarily mean the whole production line is ruined - and I'm sure if you sent AndyMark a picture they would let you know if your replacement would have the same defect.
We've done it on a prototype. It was a little scary bit it worked.
For an even more crazy number, our belts (which were what actually touched the ball) had a speed of about 5890 surface feet per minute. That's almost 70 miles per hour. The saddest part: we could barely even make shots from the key. |
That's got me wondering: what's the failure mode of #25 chain at these speeds? How is that surface ft/min rating established?
#10
Tristan- I'd also be very interested in that answer. -Brando |
