Different Swerve Drives
Having read this as well as the pleathora of other threads explaining the pros and cons of swerve, and the 1625 whitepaper on their swerves through the ages, our team would like to pursue creating a swerve drive as an out of season project. No, this does not mean we are going to try and design a swerve drive for the 2013 season.
We are designing a swerve system so that our team will, should the need arise in the future for a swerve drive, have some first hand details on how to pursue a competition swerve drive. That being said, we had a few questions that I figured ChiefDelphi would be able to answer. The first and foremost question is the wheel modules and independence of each. As far as we know, there are some basic types of module. independence: Chain all 4 modules together Chain each side together 4 Independent modules If we had to make the decision right now, we would chain each side's module together. Our reasoning behind this is because we believe this iteration is the "simpelest" method of swerve while maintaining some amount of maneuverability. As far as we have been able to tell, the added complexity of 4 independent modules for the added driving tricks added are not worth the time or research. Is this the right decision? If you could provide personal examples or logical reasoning as to why independent modules are a necessity vs. keeping sides tied together than that would be appreciated. Secondly, at CTTD this weekend I was fortunately to get a first hand look at 3928's revolutionary swerve drive modules. Between using their modules as a basis for design and buying a WildSwerve module from Andy Mark to use as a model (Blanking on who I saw that did this; been reading too many threads on swerve to remember what came from where) which would be suggested? I am leaning towards using 3928's swerve as a basis for design because it seems to somewhat help with keeping the weight of the modules down. Thirdly, wiring. The obvious implication of swerve modules are that they are not infinitely rotating, due to the twisting of the power wires. What we would like to know is if it is possible to make one that would be infintely rotating, and how one would design for this. If not then how does one ensure that the position and rotation of the wheels are correct? If this thread could be kept purely to the physical aspects of swerve that would be appreciated. There are plenty of threads and papers also describing the programming of said drive, and our programmers will visit them as necessary. Thank you. |
Re: Different Swerve Drives
What you're looking for is called a Slip Ring. These were permitted last year per R44. Slip Rings are, generally speaking, fairly inefficient. You would be much better off limiting your rotation, and it would be technically a simpler solution, I think. |
As soon as I get the project write up done I will post it to CD as a white paper and y'all can have at the critiques.
1. Slip rings. We looked into the wikipedia, and we think we understand how they work but if someone could give us a somewhat more simple explanation for us to check against that would be appreciated. 2. How would one go about steering opposite corners without using a motor per corner? We would like to keep things chained together for sake of simplicity, but with the talk of simplicity on the other side of complexity, if one can justify using individual motors but programming them as 2 motors (ie utilizing a pwm y cable) then we'll take that. I imagine that if we do use individual motors but code them as 2 then it might make a transition to full individuality simpler. Quote:
Yes this sounds somewhat counter intuitive to creating a swerve drive if we can't pull off something extreme, but we think that if we can keep the swerve drive as simple as a swerve drive can get then we might be in the clear. Quote:
As far as the technical learning benefits, that is one of the reasons we would like to pursue this. Myself and a few other kids are in a pilot FIRST Robotics Engineering class, and with CowTown over (Our only off season), we're looking for something to do each day for 2 hours until season. This being said, we are also going to do a project write up for a 6 or 8wd that may be used in season. Should it be necessary I will open another thread with similar purpose to this thread about that drive. Also note that should we only be able to do one project, the 6/8wd project will take precedent over this project and swerve will be shelved as a theoretical project. |
Small cylinders with wires protruding from both faces: you hard put them along your wire runs at the stationary-rotating interface of your swerve modules. One side's wires turn; the other side's stay still. How they do it The classic version (I think they're all like this?) and simplest way to think about it is that each stationary wire has a little brush on the end. Each brush sits on a metal ring which can rotate while still allowing the signal to transfer. Does that work? Ether: Good point. That'd be pretty neat! |
I'm back with another question/update on our process. During the mechanical design write up of this project, a mentor and I conversed about the decision to chain sides together - and he suggested we attempt full independence. His reasoning is that the long chain runs that would be necessary would be invitations to the chain hitting something then skipping. Another thing he brought up not previously thought about was the investment of space necessary to chain sides together. I also believe we will be doing Co axially driven pods, as the infinite rotations and gearing would be somewhat advantageous.
After doing swerve for 3 years, I strongly agree with MICHAEL that independent steering modules are the way to go. Swerve has many more failure modes. Having chain runs all over the robot is a night mare to work on at a competition in the pits. Our swerve modules require the removal of 4 bolts and disconnection of 3 pairs of wires to remove a module. We can remove and replace a problem module and get on to the next match. Repair it later. Doing swerve is going to increase the complexity of the robot. Try to minimize the added complexity.
Cal,
I am excited to hear the team is interested in taking on a challenge like this. Knowing the resources that 2410 has and an idea of the teams other constraints like, money, time and talent. I would say look closely at how 973 does their swerve. What I think is really nice is that each swerve section is it's own module that is then bolted to the frame. I believe this method is something that is easily visualized, delegated and tweaked. Build 4 identical modules and a box frame with a plywood electronics board. Very solid testing module. If you need any help, you know how to find me. Good luck! -Jeff P.S. send me CAD ![]() Edit to add: Cimple gears paired with 4 inch wheels seem to make a really nice combo. Last edited by Jeffy : 08-11-2012 at 11:21. Reason: Add |
Update 11.8.12
After evaluation, the team has decided to do coaxial rather than distributed. With deliberation between our programmers and me, it was decided that working with an extended travel potentiometer is much simpler for them to do rather than working with an encoder. (Coding will most likely be done in C++, for those wondering.) Our decision is thus because we believe it will be easier in the future to switch to an encoder from potentiometer once we decided we would like more than one rotation. However, some more deliberation will be had once we can get in touch with some of our mentors from Rockwell Automation. Also, at Jeffy's advice, I went over to FRC Designs and have dissected the Emperor Swerve corner module. One of the things I am wondering about after looking at this design is how to design for the rotation. From what I can see in the CAD file, the wheel module is set inside a steering bearing and this is what allows for the wheel to rotate. Correct? As well, we believe that the frame of our testing bed will be 80/20 extrusion, with the modules designed to slide on and off of the frame. As well as testing Swerve Drive on the platform, we will also look into a well-designed 6/8 wheel drive that could be slid on to the platform, so as to consolidate pricing of off season prototyping. As a last point of note, when teams do fabricate the modules, how many are created? Four would be the minimum* (No spares), and I suppose the cap would be where you want to stop spending money on creating modules. Are two extra modules a happy medium to stop at? That would mean that we would need to fabricate six total modules. *Note, Bomb Squad’s three wheel swerve is excluded from this analysis. *Edit: http://www.chiefdelphi.com/forums/sh...Emperor+Swerve has shed some light on the various mountings and bearings necessary for rotation. Last edited by CalTran : 08-11-2012 at 12:52. Reason: New information read |
#10
The main reason the programming team came back with is that it is simpler to do one analog in from the potentiometer than multiple digital or a serial input(s) from an encoder. Also, from the preliminary research they did, pricing was a little higher than we'd like to do for an encoder. Both will work for our needs, but in terms of complexity we'd like to keep it simple, and the programmers said a pot would be the better of the two in that aspect.
#12
I like to think that our steering bearing setup, and what 1717 did, are about as simple as you can get. It's just two radial bearings spaced apart to react torque and radial loads, and then a large thrust bearing to react the robot weight. |
#13
#14
The advantages to the style of module we used this year were size and weight. It was also easy to mount to whatever frame system we chose, and it kept the COG really really low. Its obviously incredibly custom and took a large amount of machining and assembly time, I was surprised at how well they held up for being a 1st generation swerve module concept. You've nailed on one of the main issues with "CIM in module" setups, the wires (kinda annoying). If you can find a slipring that can handle the amperage of a CIM more power to you, it'll save you alot of grief if an encoder ever comes unplugged. But the resource drain is enormous, and for that reason I do not see us pursuing it in the near future, I'd like to save some time for other parts of the robot so we can put on a little bit better show than this weekend (we were very very far from prepared due to other circumstances). The technical learning benefits of doing a swerve on the other hand are enormous, from Concept to CAD to Machining to Programming to Driving, you learn an incredible amount due to the complex nature of the system and the level of performance you could potentially extract from it. For that reason pursuing a prototype in the offseason is fairly okay, just be watchful of the "man this is so cool we should do it in build" as I've embarrassingly fallen victim to it so many times before, with varying results. |
#15
Motor in module swerve systems are limited in the amount of rotation you can achieve.
That said, if you run the wires directly through the pivot point and properly strain relieve the wires on either side of the joint I feel confident you could have multiple rotations without damage to the wires. It's also not unreasonable to think that you could manually unwind any module between matches that appeared to need attention. |
