Re: Cannot move robot
As I said in my original post, the robot worked at our last event, and we have not modified it electrically or mechanically since then.
Also, can someone tell me where the directory is on the cRIO for the code. I was asked to confirm it's there but I'm not sure what directory it's in. |
Just tested the compressor, doesn't start either. I think the suggestion of default code being on the robot is correct, however, after I FTP in, what directory should I look in?
Just want to quickly add after a few days of debugging the problem was resolved!
Thanks everyone who replied / helped out. |
What was the solution?
It was a mix of problems.
First one I found was when I added the compressor in the code (To test if it was jaguars or something else), I made a typo in the port. So it was (1,1), which resulted on a start up error. After that I found a robot specific issue I'm too lazy to write about, and I forgot the other one... I guess I was too excited that I fixed it ![]() |
Some friendly advice? If you come to CD asking for help, you should be willing to share what you've found when you figure it out. It's considered the courteous thing to do. Others may benefit from your experience.
I was hoping it wouldn't be a large deal :/ . I myself only found what the problem was (had to go to class), I didn't fix this exact one. I could ask the guy tomorrow what he did. The most I know was the problem and how I assume he fixed it. Lazy probably wasn't the proper word to explain that.. Sorry!
Im not 100% sure but i thought the Jags showed a green Light for Forward, Red Light for Revearse, and a orange Light for nothing because if im right about that your Jags would not be reading anything in the code.
If they are not reading it could be a couple reasons: 1. I would check to make sure you have the ports right Digital Module should be in Slot One or Two not sure which, and on the Side Car the PWM port need to be put in right. In the program your code should have: public Jaguar Jag1 = new Jaguar(1,(PWM Port Number)); 2. There is something wrong with your code and i cant help with out seeing it. If the Jags are being read by the code and are still not working, make sure that you set Jags. This means you use a paper clip on the jag reset button untill it blinks then you run your robot full speed forward and full speed backwards then it should set it self. <-- this is the way we fixed are robot jags two years ago |
I should read next time
