Go to Post Now really, who would want to try and go against Andy Baker? That's like trying to single-handedly outscore 25, 254, and your choice of triplet with a shopping cart. - Billfred [more]
Unread 18-11-2012, 19:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Bearings in Sheet Metal
Most of my experience with sheet metal was in non-power transmission applications.
How do folks typically handle bearings when working in sheet metal? If you're working in .060" or something, do you build up around the bearing with additional sheet? What about thicker materials like .090" or even .120"?
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 18-11-2012, 19:56
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: Bearings in Sheet Metal
We use .09 for our gearbox sideplates. It works fine without extra material. We also make the holes .003-.005 smaller so the bearing fits tightly which prevents slop in the gears.
Our 2012 collector had bearings in .063 sheet which supported bevel gears. There were no problems with the bearings all year. Just make sure the bearing flange is flush with the metal - it's not like its going to rip out or anything. I wouldn't suggest going this thin for a gearbox though.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 18-11-2012, 20:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
With holes that much smaller there's no chance the bearings will fit. Did you leave out a zero?
Unread 18-11-2012, 20:52
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Nope, we just use a deburring tool or ream them out to make them a little bigger after they are waterjetted. I agree that they wouldn't fit unless you make the hole bigger.
Unread 18-11-2012, 21:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Exactly or even a little emery paper does the trick. On thicker materials we note which side is tapered by the water jet and a quick hit with a deburing knife usually results in a perfect fit.
Unread 19-11-2012, 17:21
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Water jets taper the material? Hmm...I didn't know that. You learn something new every day!
Unread 19-11-2012, 17:23
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Yes, and no.
Waterjetting naturally cut a taper in the material. However, if the waterjet machine has an angle compensating head, then the cut can be straight on one side of the cut.
Andy B.
Unread 19-11-2012, 20:49
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
It's called a 'kerf'. A skilled waterjet operator such as the gut I use for work can do a really good job minimizing the kerf's taper, even without a multi-axis head like Andy describes.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 19-11-2012, 23:00
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Last summer, I was trying to cut some 1 module (metric) gears with a waterjet in about .4" thick material. Unfortunately, the kerf that yo mentioned prevented the gears from meshing properly.
Could you elaborate as to the methods used to help eliminate kerf? We tried cutting extra slow, but it didn't seem to help much. If you can cut propper bearing press fit holes with a waterjet using proper methods, to seems like cutting gears of at relatively large module would be trivial.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 19-11-2012, 23:11
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
You could just cut .125 plates and stack the gears. That would help quite a bit. Most places that we've used for work just compensate for the kerf via rotating head.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 19-11-2012, 23:39
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
You can also waterjet both gears, and run them opposite. We've done this in numerous places.
Unread 20-11-2012, 08:27
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
No idea how he reduces the kerf so effectively and I've never asked. I assume it's a trade secret of his so that we'll keep sending work to his shop.
He uses a pretty old 3-axis machine with no fancy features.
If I had to guess it's that he adjusts the pressure of the jet in conjunction with travel rate to reduce the kerf, but that's pure speculation.
Unread 18-11-2012, 21:05
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
It's funny that me and Akash just had a discussion about this the other night.
Last year 772 used 1/8" sheet (0.125") for everything and didn't thicken the area's where bearing went. Though it isn't needed we WILL be adding extra material around them this year. I am also probably going to make a "press" mechanism that will make the bearing become perfectly flush with the sheet. This year we went with cutting the bearing holes to the exact size, though with the "press" I would make it about 0.005" smaller. Along with press fitting the bearings I want to Bolt them in, the exact same way IFI bolts the bearings onto their wheels (plastic small washer to space washer, and washer on top of bearing, bolt and nut holding the washer down). The holes for the bolts would also be used to press the bearing into the metal.
You can see what I designed for a bearing press below. You need an Arbor press for it to work.
Name:	0.5 in bearing press.png
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 18-11-2012, 22:37
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
I have seen two cases where flanged FR8s (pressed in 1/8 plate) and flanged FR6s (pressed in 1/16 tubing) have had pretty great success. The most recent application was done with the FR6s for the 973 Hodgepodge Bot. So far, there hasn't been any records of the bearings or tubing failing.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
  #15   Spotlight this post!
Unread 18-11-2012, 22:49
We added extra material in the drivetrain, but straight .09 gave us zero issues for the rest of the bot.
