Go to Post Admiration is universal, it does not exclude those who have achieved past success. - hg273 [more]
Unread 19-11-2012, 09:26
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Bearings in Sheet Metal
On our intake, we needed to press in FR6 bearings in 2 places. The sides of the intake were made from 0.060" 6061 so we weren't totally sure how the press would hold up. We decided to play it safe and added 2 bearing plates that simply acted as a carrier for the bearing and would then bolt onto the intake.
The little plates actually ended up being a bit of a celebrity on the team and we ended up making them into little NUTRONs logos just for some extra flare (bottom right):
They worked out great. It was actually a cool feature too, because it allowed us to disassemble part of the intake from the opposite side where if a bearing were permanently pressed in place, we'd be unable to.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 19-11-2012, 09:38
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
-Brando
So your bearings were never pressed into the actual intake, they were only pressed onto these plates? I like that idea alot actually. Were they pressed in? Or bolted on to these plates? If they were pressed how much smaller, if any, were the holes made for the bearings?
Thanks, great idea btw.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 19-11-2012, 09:58
Yeah the bearings were only pressed into the bearing plates. The bearing plates were then bolted to the intake.
For any part that we are making in-house we can reliably undersize the press fit to 0.0005" under and press with no issue. The most reliable way to get good press fits is to invest in the 2 reamers you would need to do 3/8" bore and 1/2" bore bearings (0.8745" and 1.1245"). This becomes a very repeatable process for your team, where you size bearing holes slightly under and ream to the final diameter. You will have much more consistent press fits this way. This will also help you where you may be using a process besides a CNC mill where the tolerances on the diameter may be a little bigger (ie: waterjet). Again, you'd undersize for the waterjet, and just finish with the reamer.
-Brando
Unread 19-11-2012, 10:08
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Another thing you can do if you want to have some fun, is press the bearings into polycarbonate sheet. We discovered that a Forstner drill bit will make a hole just the right size for this press fit.
This works well for smaller mechanism type gearboxes, and I think it has been used by AM to make drivetrain gearboxes too.
Unread 19-11-2012, 10:59
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Originally Posted by sanddrag View Post
With holes that much smaller there's no chance the bearings will fit. Did you leave out a zero?
With Material that thin it works no problem. If you were pressing into material the same thickness as the bearing it'd be a different case.
Unread 19-11-2012, 11:22
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
We did this for our 2012 shooter. A total of 10 flanged bearings pressed into polycarbonate sheet. Worked great.
To put some numbers to the OP question:
Using a bearing like this one in 5052 aluminum (28KSI YS):
YS*(bearing OD*sheet thickness)=bearing load at material yield
28KSI*(.875*.0625)=1530lbf to reach yield in 5052 aluminum, assuming the bearing is seated properly and nothing is grossly misaligned. This is at least double the working load rating for most bearings of this size.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 19-11-2012, 13:13
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Is undersizing .003-.005 better for thin sheet, or is reaming out to .001 undersized still better?
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 18-11-2012, 20:33
Billfred's Avatar
Billfred Billfred is offline
For what it's worth, 2815 has had good luck with flanged bronze bushings for 1/2" shaft inside 1/16"-wall square tubing. In each case, the bushing only went through one side of the square tubing.
We ran them in our 2011 roller claw, and on our ball elevator and shooter axle this year. Any issues we had with any of these were unrelated to the bushings.
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 18-11-2012, 20:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We've done the same.
Unread 18-11-2012, 20:44
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
If you use a flanged bearing, make sure it is well retained in the plate, and pinched axially on the shaft, you'll be fine even in something as thin as 063.
-John
