Go to Post Let’s not scare the newbies away, let’s welcome them and help them. - Arefin Bari [more]
Unread 19-11-2012, 11:27
Higher Quality Wire/Connectors
What are a couple good sources for flexible and higher quality wiring for FRC bots at an affordable price? Last season we just used spools of wire another mentor had laying around, but it was not very flexible and hard to route (some Home Depot wire).
I've been to Powerwerx only so far. I'm told that speaker wire works well also. (and it looks great!)
In addition to this, what are characteristics of good quality crimped connectors (ring terminals mostly). Are nylon connectors better for stronger connections?
What is a good brand of heat shrink?
What about other ways to protect your connections than just heatshrink?
http://www.quickcable.com/products.php?pageId=462
I wanted to get something like this ^ to protect connections in certain areas. What do other teams use for something like this?
I know the answers to a couple of these questions but I'm hoping this thread can help out newer teams as well.
Unread 19-11-2012, 11:30
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Higher Quality Wire/Connectors
McMaster 9697T5
High quality wire and helps keep things clean (since wherever you are going to run a red wire, you are probably also running black...)
Unread 19-11-2012, 11:33
Originally Posted by Jared341 View Post
McMaster 9697T5
Yup Zip Cord is the stuff I was looking at on Powerwerx.
http://www.powerwerx.com/wire-cable/...-zip-cord.html
Unread 19-11-2012, 11:37
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
We get the same from a local sponsor (Orvac Electronics in Fullerton CA). Not the cheapest stuff in the world but it's great. It's amazing how much you end up using in a season.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 19-11-2012, 11:41
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We've gotten plenty of wire from McMaster in the past, it really is good stuff.
For terminals, normal crimp connectors work just fine (we pick them up really cheap at a local surplus store). HOWEVER, you should solder the wire to the connector after crimping it. I've seen too many wires pull out of crimped connectors to rely on crimping alone on our robots!
For Heat Shrink, brand really isn't going to matter. Find something cheap that shrinks down to the diameter you need. Again, I've picked most of our stock of heat shrink up from the same local surplus store.
For anything other than heat shrink, we've just used electrical tape. It's not really worth trying to cover the contacts on the motor controllers, but you should make sure the studs on the 120A circuit breaker and the power distribution board are covered! Electrical tape wraps around these easily enough.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 19-11-2012, 12:02
Originally Posted by Jon Stratis View Post
power distribution board are covered!.
Mhm, this is the only one I wanted to find something for other than tape.
Speaking of the PD board connection, I am not a big fan of the lug style connectors. ( http://www.panduit.com/Products/ProductOverviews/ProductSearch/index.htm?Ns=P_ItemSortOrder&Ne=1&R=CX35-36-CY&sid=13B1853B3B56&lastNodeId=ss_prod_powerconnec tors&N=5000001%20554%203000681)
What is a more secure option? We had issues with our lug connectors breaking at the tongue.
Unread 19-11-2012, 12:19
We use some compression lugs from McMaster (PN 6926K75 i think... we got them in bulk a few years ago, and my memory is a little hazy). They provide a double-crimp, which we then reinforce with some solder. It takes a big soldering gun to heat up #6 wire, though!
Unread 19-11-2012, 12:32
maddoctor90's Avatar
maddoctor90 maddoctor90 is offline
AKA: Matt
FRC #2481 (Roboteers)
Rookie Year: 2007
maddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to behold
You want machine tool wire (MTW). You can get this online or at a local electrical distrubuter. What most places will try to sell you is THHN. THHN has the an oil resistant coating that makes it hard to bend and work with. Also, make sure you don't get double rated MTW and THHN as this is not what you want either.
Unread 19-11-2012, 13:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Automotive wire works well too. Try a name brand like Belden, not what they sell at the low cost chain stores.
Unread 19-11-2012, 13:10
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
I recently found that 971 has some really good resources on their website.
Different materials they use, including a lot of the electrical stuff: http://spartanrobotics.org/content/m...s-and-supplies
Different Techniques to wiring:
http://spartanrobotics.org/content/r...ing-techniques
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 19-11-2012, 13:18
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I'll second the MTW wire. We were able to get a electrical supply house to donate some to us. The flexibility is much better than THHN and you also don't have to deal with the annoying nylon outer insulation jacket.
As far as the #6 wire connections to the PD: I am very much not a fan of the screw lug terminals that come in the KOP. As a robot inspector, I'm often asked to help diagnose problems with robots that stop working on the field, or even worse are intermittent. The first thing I do is look for those terminals anywhere in the wiring (battery, 120A breaker, PD). Then gently pull on the wires, which usually come out in my hand. We use crimp lugs on all our #6 wires, I don't have the part number handy but it's similar to this: http://www.thomasbetts.com/ps/fullti...gi?part=CTL614 which we crimp with a hydraulic tool.
We buy our heat shrink at Harbor Freight. Usually with a 20% off coupon
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 19-11-2012, 14:43
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
For wire we use standard automotive wire that we get at a local auto-electric shop (not a chain store) and they give us the contractors rate. It's got good flexibility and we're never had problems with it. We usually twist the black and red wires together by clamping the pair together in a drill while someone holds the spools at the other end of the room.
For wire-to-terminal connections, the quality of the connection follows this hierarchy:
  • Best: good crimp (note that a good crimp requires a good crimping tool)
  • Acceptable: crimp + solder (the primary reason that this makes a lesser connection is that the solder makes the connection brittle. For all soldered connections, it is important to make sure that solder does not wick up the wire)
  • Bad: bad crimp
For ring terminals and connections that shouldn't need to be unplugged, we use Ideal (the brand) crimp terminals and quick connects from Home Depot and crimp them with a crimping tool similar to these, that we got from Fry's. You have to calibrate the crimping tool when you get it (adjust how tightly they crimp), otherwise they'll make trash crimps. In all our years of using this tool, I can't think of a single crimp failure that can't be blamed on either using the wrong size terminal for the wire size or not inserting enough copper into the connector.
We use PowerPoles for most wire-to-wire connections. We use the crimp + solder method because the PowerPole crimping tool is pretty expensive, although I'm pressuring the team to get one.
For the battery lugs we use the crimp lugs that come (or at least came) in the KOP (not the screw type). Because we certainly can't afford the proper crimping tool for these, we solder the connection following these steps: First, if the barrel doesn't have an opening on the ring side, drill a small hole to feed solder. Next, push the wire into the connector and try to fill all the free space around the wire with solder (do this before applying heat to the connector). I do this by pushing the solder straight into the connector, cutting it flush with the connector, and repeating until I can't get any more solder into the connector. Then, take a propane torch and heat up the connector until the solder flows. You can use a soldering gun, but the torch is much faster. Finally, feed solder into the small hole you drilled in the connector (this time, keep the connector hot while adding solder). Only add solder from this end to help keep solder from wicking up the wire. Stop adding solder before any is able to wick up out of the connector.
For most of our heat shrink, we use the variety pack from Fry's. It's nice and flexible to reduce the strain on the wire. There are befits to higher quality heat shrink, but it's rarely worth it for what we do.
Jason
Unread 19-11-2012, 14:56
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
We finally caved and purchased the crimping tool for the Powerpoles last year and I doubt we will use anything else in the immediate future for wire to wire connections. While a number of students are capable when it comes to soldering connections most of students have never seen a soldering iron before joining the team.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 19-11-2012, 13:25
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
+1 for machine tool wire. It's really nice and flexible. On McMaster, it's $109.50 for a 500 ft spool of red or black 12 gauge (part numbers: 71245K41, 71245K44). 500 feet of the red+black stuff listed above would be $600.
