Go to Post Remember guys, if your mentor wasn't there, odds are, you wouldn't be either. - Corey Balint [more]
Unread 21-11-2012, 08:55
Butter's Butter's is offline
AKA: Joe Kent
FRC #0522 (Robo Wizards)
Rookie Year: 2010
Butter's is an unknown quantity at this point
Where does the cRIO save your code?
Hello Chief Delphi, I was wondering if could find the output file (In my case I'm assuming Java Jar) on the cRIO. I have already gone in via ftp (ftp://10.05.22.2), but I'm not sure of the directory I should be looking in.
Also, can I manually replace this file with what netbeans creates(Once again in my case assuming jar file)? Were having some issues with the robot moving, and someone said there is default code on the cRIO & we should make sure that it's being replaced with the new code.
Any help would be awesome!
Unread 21-11-2012, 21:24
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
Rookie Year: 2011
inkspell4 will become famous soon enough
Try re-imaging the c-Rio then upload your code
Chesapeake Regional : 2013, 2012, 2011
Rookie Year: 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 21-11-2012, 22:33
Re: Where does the cRIO save your code?
I don't have a Java imaged controller, but for LV, the startup is located under ni-rt/startup. The default program is named startup.rtexe. The default program is also referenced in the ni-rt.ini file. I believe that the tag RTTarget.ApplicationPath will point to the exe that is likely to launch your jar. This is the line, along with the startupDLLs line, that the NI loader uses to get libraries and tasks into memory and initialized.
Greg McKaskle
Unread 21-11-2012, 22:56
AKA: Joe Kent
Rookie Year: 2010
Had my question answered already, so you can ignore this thread.
For reference- It is the robot.suite file in ni-rt/system/
