Go to Post I have long since given up on these hints, and come to the conclusion that they are designed to befuddle us all and amuse Dave. - Rickertsen2 [more]
Unread 25-11-2012, 12:03
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
[EWCP] Autonomous Mode and You!
Tonight at 9pm Eastern you should join us for our cast on Autonomous Modes featuring some of the heavy hitters from around FIRST. Here's the plan https://trello.com/c/VcjhvolJ and here's the place http://www.talkshoe.com/talkshoe/web...d=98466&cmd=tc
I'll also include the outline below but check the Trello link for the most up to date version.
  • How do you plan what you'll do?
  • How do you define your strategy?
  • What sort of sensors are most useful?
  • What sort of algorithms are good for doing filtering on those sensors?
  • What tolerances are acceptable?
  • How much risk is tolerable?
  • How do you decide these things?
  • How do you handle mechanical/electrical failures?
  • How do you effectively utilize the capabilities of your robot?
  • What autonomous functions do you use in tele-operated mode?
  • How do you test your autonomous mode?
  • How much testing is required before an auton is run on the field?
  • How many autons do you have? How do you select them?
  • Chris, what tools do you use for your simulation?
  • Palardy, when creating scripting languages do they need to be real languages or can you cheat?
  • Jared, what impact does vision processing have on your auton?
  • Zach, what is the best way to start realizing that you can move in any direction? How do you utilize the omni directional capabilities of your robot effectively?
  • For your 50th percentile FRC team (think Brave Little Toaster) how much of this is possible?
  • What recommendations do you have for the BLTs out there to improve their autonomous modes?
  • Is building a practice robot important for autonomous mode success?
  • Do you see autonomous mode becoming more important (ala 2008) or less (2007)
Unread 25-11-2012, 22:17
Data Nerd
FRC #0079
Rookie Year: 2000
Re: [EWCP] Autonomous Mode and You!
Papers Discussed
Cheesy Drive http://www.chiefdelphi.com/media/papers/2536 (Not really a description but code is there, along with scripting and some other cool stuff)
Hibner Scripting http://www.chiefdelphi.com/media/papers/2553
Hibner Simulation http://www.chiefdelphi.com/media/papers/2494 (For additional reading)
Palardy Scripting http://www.chiefdelphi.com/media/papers/2497
Enginerds Open Source https://github.com/Team2337/2012ReboundRumble
Daisy Vision http://www.chiefdelphi.com/media/papers/2676
Links to US Digital Encoders
http://usdigital.com/products/encode...rotary/kit/E4P
http://usdigital.com/products/encoders
Chat Transcript
Code:
The recording has started.
<SabreBytes772> and if the name didn't make sence
<Guest 12> ok cool thanks!
<AndrewLawrence> *sense. Aaron, do we always need to correct your spelling?
Clint_Ott is logged into the chat
<SabreBytes772> yes please
<wing1002> Hi Andrew. Hi Chris. Hi Jared. Hi Zachary!
<ZachO> Haha. Loving the chat.
Guest 18 is logged into the chat
jsneer is logged into the chat
Guest 19 is logged into the chat
Guest 20 is logged into the chat
<michaelblake3481> Would adding magnetometer help with the slippage?
jsneer has left the chat
Guest 21 is logged into the chat
Guest 20 has left the chat
Guest 17 has left the chat
Guest 15 has left the chat
<apalrd> no, a magnetometer is usually less accurate than a gyro
Guest 22 is logged into the chat
<michaelblake3481> What brand encoders for the drive train?
<schreiaj> define accurate
<apalrd> more noise, more error
<schreiaj> magnetometer tends to be good over long periods of time, gyros are great in short term
Guest 23 is logged into the chat
ChannelCat1094 is logged into the chat
Guest 24 is logged into the chat
<michaelblake3481> Not possible/helpful to use BOTH gyro and magnetometer for real-time accuracy?
Guest 25 is logged into the chat
<Guest 3> in FRC probably not that useful
<schreiaj> it is, but magnetometers in FRC are hard due to EMI
<Guest 3> in real world systems with much, much longer run times, they ar emore useful
Guest 24 has left the chat
<michaelblake3481> What brand encoders for the drive train do the guests use?
<Guest 4>
Andymark
<ZachO> We ran these last year: http://www.andymark.com/product-p/am-0180.htm
<michaelblake3481> Thought that's what they said... so, U.S. Digital, right?
<schreiaj> us digital is solid stuff
<AndrewLawrence> ^
<michaelblake3481> Okay... THANKS!
<AndrewLawrence> U.S. Digital makes great encoders.
Guest 18 has left the chat
<Guest 6> Do you have trouble with a sensor being shut down in error?
Guest 19 has left the chat
Guest 26 is logged into the chat
Guest 22 has left the chat
<SabreBytes772> This yea we tried to "record" an Autonomous mode. We (Driver's) would drive the robot through a cycle and then e could replay it.
<SabreBytes772> It didn't work perfectly enough to use for competition
<ZachO> We talked about doing that for a while
<SabreBytes772> we just used times for Auto
<wing1002> what I use is a system of 'stages'
<wing1002> i divide autonomous into threaded stages
<wing1002> and each stage , upon completion, throws a flag, and once all the threads catch a flag, the stage is incremented
<wing1002> that's how I did auto
AndrewLawrence has left the chat
<Guest 12> do you test one thing at a time? like once driving forward works consitantly, then add something?
<ZachO> Yes
<ZachO> We go through it systematically
Guest 21 has left the chat
<ZachO> If anyone wants to see 2337's auton scripts they're online https://github.com/Team2337/2012ReboundRumble/tree/master/Autonomous%20Scripts
<michaelblake3481> Do the guests believe it's important for EVEN Top 8 teams at Regionals/CMP Divisions to already have in place mechanics/programming...
<michaelblake3481> ...to feed their game piece(s) to a stronger Autonomous scorer?
<Guest 3> either have it already written, or have a framework that lets you write one in <5 minutes
<michaelblake3481> Anyone else lose audio?
<SabreBytes772> linky?
<schreiaj> refresh page michael
<schreiaj> sabre, ill hunt down a link in a bit
michaelblake3481 has left the chat
<SabreBytes772> alright thx
michaelblake3481 is logged into the chat
Clint_Ott has left the chat
<SabreBytes772> we press play and hope for the best?
<SabreBytes772> well Enable, not "play
Guest 13 has left the chat
<Guest 12> whos from 341?
<schreiaj> guest 3, jared russel
Guest 27 is logged into the chat
Guest 27 has left the chat
Guest 4 has left the chat
Guest 28 is logged into the chat
<SabreBytes772> it was delayed for us when we tried doing our vision on the dashboard. now we're trying to learn how to use a beagleborad
<Guest 6> We took pictures and modified them in photoshop to obscure goals
<michaelblake3481> Rather than adding Beagleboard (additional failure point) wouldn't it be better to upgrade the laptop to perhaps "gamer" level?
<Guest 3> we used a core 2 duo laptop in our driver station rather than the classmate (341)
<apalrd> you're more limited by radio bandwidth
<apalrd> we ran a core 2 duo as well
<Guest 3> worth noting: in 2013 you are limited to 10mbps per team
<Guest 3> in 2012 there was no limit
<Guest 6> Guest 3, where was the limit announced?
<michaelblake3481> 10mbps is a good amoint, right?
<michaelblake3481> *amount
<Guest 3> i am trying to find it
<Guest 3> i want to say it was in the dump of information after the einstein investigation
<Guest 3> for reference, with our dark 640x480 30fps camera feedback we were pulling ~6mbps
<Guest 3> only an issue if you have several cameras, high resolutions, high fps, and poor compression
<Guest 6> The einstein report said they were investigating bandwidth limits, but didn't list what they will be, or even if there will be limits
Guest 29 is logged into the chat
Guest 30 is logged into the chat
<jimzondag> yes, all teams need to be able to stand still if needed
<Guest 28> where are these resources?
<ZachO> Chief Delphi
<jimzondag> cd white papers
<Guest 28>
Could you please post the links?
<schreiaj> ill do my best to hunt them down after the call
<Guest 28>
Thank you very much
<SabreBytes772> write them down on a post it note to not forget which one's your looking for lol
<SabreBytes772> Thanks
<ZachO> http://www.fightingpi.org/Resources/Controls/Beta/2013_Beta/11-4-12_Day_10.shtml
<Guest 28>
Is there any paper describing chesydrive in detail?
<schreiaj> im out of hands someone write them down for me :P
<Guest 3> there are some threads on Delphi
Guest 31 is logged into the chat
<Guest 6> http://forums.usfirst.org/showthread.php?t=19891
<SabreBytes772> LabView made it I saw a video of them presenting it
<SabreBytes772> ours were really close this year. Mentor changed it for us -.-
<SabreBytes772> he changed up the shooter for his way. instead of the design
<Guest 6> For the quick switch code, what do you use to trigger the practice vs real robot decision?
<schreiaj> In 79's case, we don't build a practice bot. Our CSV was on the CRIO, I never know constants
<ZachO> It's not automatic
<ZachO> We have to set it in the code.
<Guest 29> May use Kinetic to select a target similar to the remote in 2008.
<Guest 29> Don't forget, there is a remote in FIRST Choice.
<SabreBytes772> 3 minute matches.
<Guest 29> ugh
<Guest 29> 2011 & 2012 had excellent auton tasks
<SabreBytes772> agreed
<SabreBytes772> Final words: Auto/Hybrid is useful. the end.
mwibbels has left the chat
<jimzondag> most matches can be won by only doing auton and endgame
The recording has ended.
Unread 25-11-2012, 22:21
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Originally Posted by Andrew Schreiber View Post
Just a note: the Scripting paper includes the latest and greatest simulator, so you really don't need the 2nd paper unless you just want to read the document.
An ounce of perception is worth a pound of obscure.
