Re: Be afraid... Be VERY Afraid
Again, read the thread. It was officially announced, complete with full CAD of what it actually is.
That is beautiful! You'll have to let us know how well it works. And tell your programmers I'm praying for them...
Is this wheel device for driving over a Frisbee? One wheel up off the ground to get over the Frisbee and a second wheel to stay on the ground.
Might a mod change the thread title or close it? This seems to be happening a lot... |
I think it's a bluff
980 in 2003 used something very similar, using smaller wheels for speed and larger wheels for climbing a ramp (at least, that's what I recall them doing--it might have been the other way around). I think some other teams have done something similar. We've also seen swapping mecanums and traction wheels, as well as omnis and traction wheels. I designed one once, but it didn't get past the team brainstorming stage.
This is one quarter of a wheel-shifting drivetrain, where two different types of wheel can be changed at will, or used for climbing. Again, I don't think this is exactly revolutionary for FRC--similar things have been done on several occasions. Now, the real question is: have you locked into using this for next year? If so, I highly suggest reconsidering. Quite simply, you don't know what the game will involve. (Hey, wheel-less robots are always an option for the GDC...) So, the thing that I'm more afraid of is: http://www.andymark.com/product-p/am-superoptions.htm |
I don't think it flips 180, as that CIM will have a hard time going through the mounting material. I think it's just aesthetically pleasing.
Well, it's obvious you're itching to tell us more...so out with it!
#10
The wheels seem cantilevered. I think thats different from the usual octanum setup.
#11
In 2004, HOT (67) had a very similar system where they had two wheels on each side of the robot that were powered by the same motor. Each wheel was actuated downward to touch the ground. This allowed them to change speed/torque ratios.
Notice the two different size black treaded wheels on the right side of the robot in the picture below. ![]() Last edited by Starke : 25-11-2012 at 22:12. |
#12
Well, it looks like by changing which wheel touches the ground, you can also change the clearance under the chassis. The hard stop looks like the vertical mounting touching the cim (The piece of metal which looks like a bell curve in the back). It looks like you could add 3, 4, maybe even 5 inches in your floor to chassis clearance.
(The big wheel looks like it can rotate clockwise all the way to where the little wheel starts) Still want a top/bottom view ![]() Last edited by ehfeinberg : 25-11-2012 at 22:11. |
#13
What it is is it's a pivoting drivetrain section. If there is something else that is part of the drivetrain, that makes it different from any other pivoting drivetrain like an octocanum or the pivot-shifters of yesteryear, then it's either not put in or very well camouflaged. Unless those two bolts at the near visibility side indicate modularity, that is, the ability to swap it out for another module in drivetrain, I think you need to raise the stakes significantly--say, pay $100 and hire whoever guesses correctly to decipher the game hint for you. (Incidentally, the modularity concept could run you into some trouble if you don't do it right--all modules go through inspection at the same time.) |
#15
