Re: Be afraid... Be VERY Afraid
Could we get a top down view?
Wait, the slot near the big wheel looks the same size as the other side. Can this thing flip 180 degrees?
Is this the completed assembly? Another guess of mine is that in addition to having different speeds, based on which wheel is touching the ground, you could have different wheel bases. So basically, in one orientation(likely the one with the higher speed) you have a smaller wheel base, therfore you can turn easily. On the other hand, when the other wheel is touching the ground(likely the lower speed), you will have a larger wheel base and therefor it will be harder for you opponents to turn you. |
Anyways, is there a reason you are using belts and not gears for this? Is it for a more quiet operation? Are the wheels of different material? Is one grippy for more traction but one slippery for ease of turning? Maybe this isn't a swerve, but a fixed unit and you have the slippery wheels to ease turning a 4-wheel long bot. But I doubt its as simple as this ![]() |
Is it a 2 speed transmission where you shift which wheel is on the ground to shift the speed?
Here's a top view for ya
While driving one way it uses one of the wheels, when it reverses the belt/wheel setup pivots around to go onto the other wheel with a different torque/speed.
For viewing convenience:
Renders: here and here DanielDTech in blue
[/ImTooMethodical] I'll guess later. |
Is your mechanism inside the wheels? Internal gearing/anything?
*begins to lose interest* |
#10
I believe he's missing the encoder.
Don't forget your sensors. |
#11
"Hey guys, check out this super awesome thing I made, which is exactly what multiple teams made 8-9 years ago, with some revolutionary component missing. You have no possible way of guessing what is missing because I've given you absolutely no details, but I will string this thread along for the next month because it's fun to have lots of people wondering what my (not so) revolutionary design will be"
Does that about cover it? |
#12
I've made some edits, please review. |
#14
And why should I be afraid? Is it because if your robot is on the field, then mine should not even be used because yours is that awesome. |
#15
I believe this post was intended to generate hype...but the response being generated isn't exactly what I'd call hype. It's just not the nature of CD. "Be afraid" -- really? This isn't really how folks share ideas in this community, but it's interesting. Good luck with the design, and I hope you're well into the fabrication and testing phase for your prototype if you have any plans of using this in 2013.
