Re: pic: Another concept study
Last year we ran at about 10.7 fps and had no trouble. With the traction wheels we don't need to worry about the Mecanum's lower pushing force so we can run faster. This concept is at 13 fps but that doesn't mean we would ever build it that way. Our driver said he didn't go to full speed at 10.7 fps very often so faster than that would have be a need driven by the game. |
I love this design (and the detail in the model), but I cannot see how are you going to make the hollow round housing like that for the traction wheels? I am sure I am missing something but it looks like it is just machined from one solid block of aluminum.
Yeah - that one is a bit messy. I have it designed as a tube with end plates welded on and then machined.
I would recommend changing the setup so that the pivot is on the traction wheel and not the mechanum. The reason is that you will see a large bending force on your pivot if you are in traction mode and you get pushed from the side. The distance from your traction wheel to the pivot will act as a moment arm and can reek havoc. Now you are using box tubing which has a great bending strength, but you are also using that same box tubing to house a gearbox, so even a slight bend can really foul up the works.
This is a lesson learned from experience on 148. Take a look at the differences in the drive train between 2010 and 2011. |
I've been studying the details of this render in several sittings, and I'm still in the process of absorbing some of them. This is really neat stuff. Thanks for posting!
It looks to me like the speed on the traction wheels would be something like 3.5 times slower than the mecanums, based on wheel size difference and a guess that the traction wheel's gearing is about 2:1. |
Ah, yes. I missed the fact that the traction wheel doesn't get the second stage reduction that the mecanum wheel gets.
My software-addled brain is having trouble visualizing how face-mounted cylinders can follow the arc the traction wheels make when extended downward.
#10
It looks like they aren't facemounted, but rather front pivoting cylinders. The crossholes in what appear to be the mounts must be what they rotate on.
#11
Last year we did use fixed cylinders with the traction wheels. The arc error was only about 0.010" so we made the holes oversized to accommodate it. With this concept the tractor wheel rotates too much for a fixed cylinder. |
#13
Our team is looking into this kind of designing. |
#14
I used Creo Parametric 2.0. It's free to First teams. It does take skill but no time like the present to start learning.
#15
Does this program come included in the Kit Of Parts? Or must we request it separately? Also, how do you get FIRST pieces into the program (ex: the CIM motors, omni wheel)?
