Go to Post If I can do it, it's not art. - Ether [more]
Unread 28-11-2012, 19:44
PaulYavarow PaulYavarow is offline
FRC #1768
PaulYavarow is an unknown quantity at this point
Turntable vs. Slew Bearing?
We at team 1768 are working on a pre-season training project. Since it is a training project we, decided to include a turn-table into our design. However, our team has no experience with turn-tables. We need to mount the arm from our 2011 robot onto a turntable. This is a low budget project, and we intend to only turn 180 degrees in each direction.
The question I have for you all, is what are the pros and cons of using a slew bearing versus a turntable?
Unread 28-11-2012, 21:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Turntable vs. Slew Bearing?
What you want is called a "lazy susan" bearing. Slew bearings are generally for large loads, like on a crane, and are very expensive but if you have one, go ahead and use it.
Lazy susans are very inexpensive and better suited to the speeds and loads encountered in FRC.
Why "susan"? I dunno, maybe she is lazier than the other girls....
Unread 28-11-2012, 22:07
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
First choice just happens to have an Igus slew ring bearing listed. Go to their website for dimensions and more info.
Unread 29-11-2012, 16:51
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
We've ordered from VXB.com several times an been very pleased with the result.
Last year we used these on our turret:
http://www.vxb.com/page/bearings/PRO...Susan/Kit11280
Poke around their website. They have a very wide selection. I'd probably go a step or two up from the 400 lb one if you are supporting an arm: the cantilever and shock loads on them can be quite high.
Unread 29-11-2012, 18:36
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
I second this lazy susan. My team used the one on FIRST Choice at first last year until our robot took a dive -- the bearings fell out. We then found this lazy susan to replace the broken one. It is built much better, and can take side loads better.
Unread 02-12-2012, 01:57
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
Team Role: Coach
Rookie Year: 2011
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
We third this recommendation. We used VXB as well. Great and affordable to boot.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 02-12-2012, 11:02
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
These are priced a bit higher but seem to be somewhat thicker. We had one blow apart after the bot fell off its cart but were able to put it back together. It lasted another two years before the housing finally cracked.
http://www.leevalley.com/en/wood/pag...50,43298,43316
