Go to Post Hey, I'm not my dad, I dont know anything! - Lil' Lavery [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 02-12-2012, 20:45
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
CNC Tooling
My team is ordering its firct cnc mill, a haas TM-2P, and I'm not quite sure what tooling to get. So far this is my list with the different questions I have. I'm thinking of buying a large part of this from Lake Shore Carbide and Maritool:
1/8" - 3/4" End Mills
  • Do I need both roughers and finishers? How are the combined roughing and finishing end mills from Lakeshore?
  • Which is better: Lakeshore variable flute end mills for aluminum or Maritool aluminum high helix end mills?
  • For the maritool high helix finishers, which is the best coating?
  • Should I get corner radius end mills in addition to square end mills?
  • Should I get reduced shank end mill or regular length? Both?
4-40, 6-32, 8-32, 10-32 Specialty Aluminum Taps from Maritool
  • Is spiral flute or spiral point better?
Reamers
  • Do I need to get reamers for each of our common bearing sizes, or is the TM-2P precise enough with a regular end mill?
Drill/Mills
  • Is it better to giet idividual tools for counterskining, chamfering, and spot drilling?
Ball End Mills
  • Lakeshore variable flute ball end mills for aluminum vs Maritool 3 flute high helix end mill for aluminum?
Face Mills
  • Which seller is best?
  • Should I get multiple types(i.e. 45 degree and shoulder)
  • What diameter should I get?
Drills from maritool
  • Should I get screw machine length in addition to regular?
  • Is carbide worth it?
  • Should I get the 3 flute drills from maritool?
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
