Go to Post "Magnificent" is the only appropriate adjective for a handlebar moustache. Kudos. - Lil' Lavery [more]
Unread 03-12-2012, 21:08
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Custom ports
I know there is this rule out there somewhere but I cant seem to find it.
What ports are we allowed for direct driverstation-to-device_on_the_robot communication?
Long story short we might want to put a computer on the robot and communicate directly to it from the driverstation.
Like, for example, can I just pull up the robots IP and connect on port 1002 to it and send whatever I want over that port to the robot? Is this making any sense?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 03-12-2012, 21:53
omgnocomms's Avatar
omgnocomms omgnocomms is offline
omgnocomms will become famous soon enoughomgnocomms will become famous soon enough
Re: Custom ports
According to the FMS White Paper1,
Originally Posted by FMS White Paper
The ports that the teams are able to access on the playing field are as follows:
TCP 1180: This port is typically used for camera data from the robot to the DS when the camera is connected to port 2 on the 8-slot cRIO. This port is bidirectional on the field.
TCP 1735: SmartDashboard, bidirectional
UDP 1130: Dashboard-to-Robot control data, directional
UDP 1140: Robot-to-Dashboard status data, directional
HTTP 80: Camera connected via switch on the robot, bidirectional
HTTP 443: Camera connected via switch on the robot, bidirectional
All these ports are open on the playing field, so a team can use them as they wish if they do not employ them as outlined above (i.e. TCP 1180 can be used to pass data back and forth between the robot and the DS if the team chooses not to use the camera on port 2 of the 8-slot cRIO)
Since this is not one of the ports outlined in the FMS White Paper, this wouldn't work on the field.
Unread 03-12-2012, 22:08
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Custom ports
The ports were also defined in a 2012 team rules update, so check the rules released in January and watch for those Team Updates this year.
Unread 04-12-2012, 06:36
dellagd's Avatar
AKA: Griffin D
Rookie Year: 2011
Re: Custom ports
Thanks! Thats what I needed!
