Go to Post Batteries don't help you if they're lying on the field. - Kevin Sevcik [more]
Unread 12-04-2012, 01:03 PM
sampelje sampelje is offline
FRC #3104
sampelje is an unknown quantity at this point
Wink How to Manually Remove FRC Plugin - Netbeans
Team,
We have a corrupted install and the Netbeans plugin manager does not show the FRC plugins in it's management console, but when you try to download/install them it then says they are already installed.
So the questions is what file/files does one delete to convince Netbeans that the plugins do not exist and thus need to be or can be reinstalled.
Think of it this way how would you totally remove all reference of the FRC plugins. By the way - a "reinstall" of Netbeans and deleting the Netbeans cache file structure does not solve the problem.
Thanks All
