Thread Tools |
Rating:
Display Modes |
Re: VEX Robotics Relaunches VEXpro Product Line with over 120 New & Improved Products
http://www.vexrobotics.com/vexpro/wh...on-wheels.html |
A single hub is more than enough to transfer the torque. So I would recommend a single hub, and a hex bearing for piloting on the other side.
Our reasoning for relaxing the requirement was that since the full torque load could be taken by one hub, then a hex bearing can be used on the other side if you are worried about deflection. As it turns out, the bearing solution is less expensive for the customer anyway. Paul |
It's also a great use for the handful of seized hex bearings we have collected through the years.
A few people asked about whether we would sell the shifter shafts independently. The answer is "yes" and they're already live on the site (linked from the kit contents section of the Ball Shifter page).
Short Output Shaft (w/ gears) -- as used in the 3-stage gearbox. http://www.vexrobotics.com/vexpro/ge.../217-2793.html Without gears... just the shaft: http://www.vexrobotics.com/vexpro/ge.../217-2791.html Long Output Shaft (w/ gears) -- as used in the 2-stage gearbox. http://www.vexrobotics.com/vexpro/ge.../217-2792.html Without gears... just the shaft: http://www.vexrobotics.com/vexpro/ge.../217-2790.html -John |
![]() Sincerely, Andy Baker Last edited by Andy Baker : 10-12-2012 at 13:57. |
JVN or Paul, can you explain how the VersaPlanetary motor connectors work? I've looked through the CAD and I see the set screw, the collar type thing with the slit and the place that it goes. My real question, "is the setscrew the only thing keeping the motor engaged?" I do like the access holes for the setscrew, and that you can swap motors with out removing the gearbox from the robot.
I'm excited to get VEXpro parts in. |
Allen, The motor connection that the VP uses is one of the more counter intuitive engineered items I have come across in my time as an engineer. This technology is used on industrial robotic gear boxes all over the world and is becoming the common adapter for high rigidity, low backlash applications. There are two basic principles at work: (1) The motor pilot is not used, but the shaft is actually used as the pilot. (2) The set screw really isn't used as normal set screw (clamping on a rigid shaft). It is used as a clamping lever to squeeze the C-coupling into an ellipse. The C-coupler (collar type thing with the slit) and the input collar (the thing the C-coupler fits into are precision machined for an exact slight clearance. In addition, you use a specific C-coupler based on the motor shaft diameter. There is a different coupler for 3mm, 1/8", 1/8" with knurl, and 5mm shafts all with the same OD so they fit in the input collar. The clamping screw is tightened (don't really need that much tightening torque) and turns the C-coupler into an ellipse which locks it in place with no backlash. I have accidentally hand tightened a coupler before and it still locks solid. It took me over 9 months of rigorous testing when I was at FANUC to approve this technology for use on our robots, but after the testing I was sold. easy for replacing bad motors, easy for replacing the gear sets, and no more press fitting gears on motor shafts. Now for high end motors like industrial robots use, this next benefit really isn't a benefit, but for some of the less expensive, non-high tolerance motors we use in FRC, I have found that this next benefit is really helpful: Since you do not have to completely clamp the motor face to the VP mounting face, any shaft runnout misalignment between the motor shaft and motor mounting face is completely mitigated by just hand tightening the mounting motor plate mounting screws. Since the screws only act to keep the motor case from spinning, they only need a little loctite and hand tightening. We will have detailed diagrams on how this all works prior to kickoff. Paul |
#10
![]() (Picture is of a gear being used on one side of a wheel, versakey on the other, just in case the photo gets removed/updated to reflect changes) Would you replace one of the hex hubs with a bearing hubs and then rely on the gear's hex and VersaKeys to transmit Torque? Last edited by thefro526 : 10-12-2012 at 00:04. Reason: Don't type while half asleep. You'll forget words and letters on the end of words. |
#11
-John |
#12
Turns out a 1/2" hex bearing on the other side to pilot is more cost effective than another hub anyways.
#13
Does this apply to the 1/2" keyed hubs as well? I am assuming so but wanted to confirm anyway.
#14
Yes, this applies to those.
#15
And I had just finished putting together my pre-season orders. Back to the drawing board.
