Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 07-12-2012, 10:01
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Rookie Year: 2010
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
.stp to inventor files
With the new VexPro items out, now might be a good time to learn how to convert a STEP to whatever file I would need in to read it in Inventor.
Would anybody please enlighten me? I know that there are downloadable converters, but doesn't inventor have a converter built in? If so, this is what I would prefer to use.
I am going to need this for 2013, as my team is making the upgrade over winter break.
Thanks!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 07-12-2012, 10:04
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: .stp to inventor files
Inventor will convert the files by itself. When you open the files, change the file type to "any files" and just open it. Then save the file, and it's now in Inventor (ipt or iam) format.
Unread 07-12-2012, 10:11
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
A couple of small things to be aware of when you do this import:
(1) The STEP conversion will convert all files of the folder to inventor format. So if you have a gearbox STEP file, you get the ipt files for all parts in the file. Usually it's in a sub-folder labeled "Imported Components" or something.
(2) The STEP conversion doesn't appear to keep constraints (or at least, not that I know of). So once you load in a part, either constrain all of the parts, or just save the file and don't touch anything.
- Sunny G.
Unread 07-12-2012, 10:29
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Team Role: Coach
STEP files don't have materials selected, either, so you have to go in and tell each part that it's made of aluminum or steel or whatever if you want to use it for weight and CoG later on.
Last summer I went through a process of creating all of my own AndyMark gearbox assemblies with the constraints the way I liked them, colors adjusted, materials entered, etc. I imagine that I'll be doing something similar over winter break with the Vex Pro stuff. It's nice to have an organized library of COTS parts.
Unread 07-12-2012, 10:40
UAH Class of 2019
Rookie Year: 2010
Thanks for the help... I know what I am doing tonight!
Unread 07-12-2012, 12:07
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
1. Unzip the download file. Creates a folder containing the STEP file.
2. Open the STEP file in Inventor (choose "File of type: STEP" in the open dialogue box to locate it) The assembly and parts are contained in a single file.
3. Save.
4. Inventor creates a new folder in the "Imported Components" folder containing the new .iam assembly file and all .ipt part files.
5. Parts are properly located but unconstained in the .iam file. You may wish to ground all parts if you do not resconstrain the entire assembly.
6. Parts have no material selection or iProperties.
