Re: Incorporating the vex ball shifter into a WCD Drive
I'm picturing a wider custom version of the 3rd stage add-on that Vex sells. Put your two sprockets inside and change the 3rd stage ratio to be appropriate for direct drive. Sounds like a fun winter break project.
If you are able to remove the hex output shaft pressed into the ball shifter shaft and replace it with your own, you could just add some pulleys/sprockets and a couple standoffs like the attached picture. The picture shown has 30 tooth pulleys and the clearance with the 4 standoffs is close... to get more clearance with smaller pulleys/sprockets you could rotate the entire gearbox slightly about the output shaft and use the 2 standoffs in the upper left/lower right corners (2nd picture). Would be good to work in some more support for the cantilevered gearbox.
We are thinking about doing this with belts and just using the 1x3 as the mount plate for the third stage with larger standoffs. Which would allow for the pulleys to be contained in the 3rd stage of the gearbox. |
I made this yesterday, but I think we might be pursuing a different option at this time.
The ratio on this is 12:50 1st Stage - CIMs 14:50 1st Stage - Versaplanet 4:1 (I like just putting it in on the plate just to have the option.) 50:44 High 34:60 Low 30:40 3rd Stage Edit: Probably should have added another view to be more descriptive. Last edited by James Tonthat : 14-12-2012 at 13:01. |
