Go to Post I have never seen a coach with a better ability to yell with love. - IndySam [more]
Unread 17-12-2012, 18:58
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
Team Role: Leadership
ferret_guy is on a distinguished road
Using 2 cRios to issue commands
are there any rules agense using 2 cRios to issue commands?
Unread 17-12-2012, 19:15
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Using 2 cRios to issue commands
One and one only.
I doubt that rule is likely to change for 2013.
[R52]
Robots must be controlled via one programmable National Instruments cRIO (part # cRIO-FRC or cRIO-FRCII),
with image version FRC_2012_v43. Other controllers shall not be used.
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
why do you need 2 cRios ?
Ed Barker
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I should probably warn you that in about two weeks, that sort of question will result in a "You should really, really, read the Game Manual". But, seeing as I don't know what the 2013 Manual will have to say, I'll refer to the 2012 Game Manual, Section 4.1.9, which has all the 2012 rules on the control system.
[R52] specifies one programmable NI cRIO to control the robot (along with firmware revision), and that other controllers shall not be used.
The blue box for [R65] explains that per [R52], the robot must be controlled by the cRIO; other devices (custom circuits) must go through the cRIO to originate command signals.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 17-12-2012, 19:49
apples000's Avatar
apples000 apples000 is offline
Rookie Year: 2012
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
I'm pretty sure that all your motors must be controlled by one cRIO, but I think that you might be able to have another cRIO that just has power/network, although I can't think of a situation when this is necessary. If you need extra processing power, you could just use the driver station laptop. Even the classmate laptop is many times more powerful than the cRIO.
Unread 17-12-2012, 23:02
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Insert standard disclaimer regarding past and future rules here.....
We (the Lead Inspectors) were asked this question last year at Championship, and after a little research and discussion this is what we came up with:
All commands to motors, pneumatics, etc, have had to come from a single cRIO in past years. It is legal to have a second cRIO on the robot for other purposes, the one that has come up a few times is teams wanting to use it for vision processing. A 4 slot chassis is able to be purchased by all teams (without modules) for less than the $400 limit, making it a legal COTS computing device for use on the robot.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 18-12-2012, 14:04
AKA: Mark Omo
FRC #1703 (RATS)
Ahh thank you all I was thinking of having them issue commands and red the rule you mentioned the word ONE kind of slipped by
