Go to Post Welcome to FIRST! It's in your blood now... - AmyPrib [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 19-12-2012, 21:44
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Rookie Year: 2012
Robo Hamsters is an unknown quantity at this point
Team 4466 - Corner Riser Design
Hello All,
During some CAD training exercises we came up with a corner riser design useful for creating a double-level drive base so we decided to share it here for all to use.
You can download the design from this page on our website: http://culpeper-robotics.org/structural/
Hope someone else will find this useful.
Enjoy
Unread 20-12-2012, 08:07
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: Team 4466 - Corner Riser Design
Nice work.
I wonder if the folks from AndyMark might be interested in this concept ...
Hi!
Unread 20-12-2012, 08:24
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
One comment (just based on some reasonable amount of sheet metal fabrication experience although I won't claim to be an expert). The final bend in the vertical plane would require a specific length punch to fit inside because of the very small gap (the die could still be full length). If you opened that up so that a full length punch of some thickness would fit then (I know 1/2" would work but possibly 1/4" are available over the length of the flange) you could use standard tooling on any press brake.
Close enough to taste it, too far to reach it
Unread 20-12-2012, 10:09
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Another reason is you will need a bit of clearance for spring back when it gets bent. It's bendable as is, if the shop has sectionalized punches but as Gary pointed it, it would make it a bit easier for the shop. Although, sectionalized punches are pretty standard. I might put in a relief where the bends meet.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 20-12-2012, 13:02
Rookie Year: 2012
Gary & James,
Thanks for the suggestions. You are both correct. As I said this was a training exercise we did to teach some CAD concepts. The design probably could be a little better. A gap where the flanges meet probably would be a great idea especially as it would also help make the part slightly (not much) lighter too. Possibly also could use some weight reducing holes in the vertical faces as well.
Anyone that wants to use it can feel free to do so, and also feel free to modify it and make it even better.
@Taylor: It would be really cool if AndyMark picked this concept up and ran with it. Might even send them the design.
Unread 21-12-2012, 09:16
Rookie Year: 2012
Here is Revision 2 of the corner riser design.
This can also be downloaded from our website at http://culpeper-robotics.org/structural/
Unread 23-12-2012, 17:58
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
I like the bracket in the first revision. If you needed it to be stiffer you could add a tack weld to keep the flanges from separating if there is a twisting load. When forming the flanges there are a couple of different ways to get the final bend. There is air bending with a 89 deg die and and coining with a 90 deg die. It all depends on the material type and the minimum bend radius for the material thickness.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 23-12-2012, 18:02
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
I like the bracket in the first version . If you needed it to be stiffer you could add a tack weld to keep the flanges from separating if there is a twisting load. When forming the flanges there are a couple of different ways to get the final bend. There is air bending with a 89 deg die and and coining with a 90 deg die. It all depends on the material type and the minimum bend radius for the material thickness.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
