Go to Post PS: When/if it gets to be too easy to build a machine that can accomplish a recent/typical FRC game, then I suspect it will be time for someone to unveil a harder game. - gblake [more]
  #16   Spotlight this post!
Unread 21-12-2012, 21:20
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Bumper easy attachment?
links 3 and 4 fail, Adam. Ellipses in URLs leave out essential info.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #17   Spotlight this post!
Unread 22-12-2012, 03:44
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Rookie Year: 1997
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Aahh, thank you very much. I actually just copied that from a previous post of mine, and I forgot to redo the links. It should all be fixed now. Thanks!
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
  #18   Spotlight this post!
Unread 22-12-2012, 17:02
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
I did a quick sketch of what our brackets have looked like in the past. Angle stock attaches to the bumper itself while the square stock is mounted on the robot, we use this stock to build most of our frame. A drop pin then goes through all three pieces holding it in place. Usually a long section of bumper has two to three of these while a shorter bumper has two.
Since I can't get the image to upload here is the dropbox public link:
https://dl.dropbox.com/u/32389675/bumper%20bracket.png
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
  #19   Spotlight this post!
Unread 14-01-2013, 14:32
rguetter rguetter is offline
AKA: Rick Guetter
FRC #4678 (Cavaliers)
Team Role: Coach
Rookie Year: 2012
rguetter is an unknown quantity at this point
A second set of bumper covers seems really simple and much quicker than removing and attaching a red and blue set.
Is there a problem with R28 - BUMPERS (the entire BUMPER, not just the cover) must be designed for quick and easy installation and removal?
  #20   Spotlight this post!
Unread 14-01-2013, 14:44
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Team Role: Teacher
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
All they are saying is it shouldn't take you a ton of time to get the bumpers off, cover or no cover.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
  #21   Spotlight this post!
Unread 14-01-2013, 15:23
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Originally Posted by ttldomination View Post
To you folks, since the connection isn't necessarily rigid/bolted, what's preventing "play" in the bumpers? I'd image that if you have have a 1/4" pin into a 1/4" + some set of holes, you're going to get some play?
- Sunny G.
The C shape of the bracket and tight fit on the frame rail keeps it from twisting. The vertical pin should have a tightish fit in the hole combine to create basically a box around/through the rail and keep it from pulling away. It rattles a little, but doesn't move unless you've got too much tolerance in either the bracket or pin hole. Here's some ascii art:
Code:
|||   |  robot insides ->
  #22   Spotlight this post!
Unread 14-01-2013, 17:54
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
We take some 2"x2" aluminum angle and rip 1" off one side and drill some 1/4" holes to mount to our frame and on the other side we cut what amounts to an "L" shaped slot. Each piece is about 3" long and we usually have 3 for each side bumber and 2 for each front and back.
The bumpers have a small plate mounted to the plywood behind each bolt hole under the pool noodle. A 1/4" bolt is threaded into a tapped hole in each of these plates.
To mount the bumpers the bolts drop into the "L slots" and then we push them so the bolts are seated in the L and then tighten them down with Gearwrenches.
  #23   Spotlight this post!
Unread 15-01-2013, 01:00
Brian3512's Avatar
Brian3512 Brian3512 is offline
Head Coach
AKA: Brian
FRC #5102 (Santa Maria PAL Robotics)
Team Role: Coach
Rookie Year: 2011
Brian3512 is an unknown quantity at this point
We use a C piece of aluminum that hugs the frame and there is a quick release pin on it. Makes bumper swaps very easy
  #24   Spotlight this post!
Unread 15-01-2013, 16:01
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Last year we made it so the corner pieces of the extruded aluminum frame were vertical with stops on the bottom. We attached those lovely teflon sliders to the back of the bumpers and threaded some 1/2" bolds on top to keep them. We could change a full set of bumpers with one drill in under a minute.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
  #25   Spotlight this post!
Unread 21-01-2013, 17:32
JesusC JesusC is offline
FRC #4633
JesusC is an unknown quantity at this point
Question Re: Bumper easy attachment?
Hey guys, we are a first year team, and we dont really have that much money to spend on velcros and other stuff to only need to attach the colored cloth.
Just to double check, we only need to remove the color covering in less than 5 minutes, right, so if we have the bumper assembly separate from the covers, they could be separate right? if so, what would you suggest we do, should we make two different bumpers and have to take them out, or should we try and have a way to remove only the cloth.
If you have any ideas on this, please share, because we have alredy spend an entire day discussing this, and we are still undecided Thx
  #26   Spotlight this post!
Unread 21-01-2013, 23:48
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
We've used these before. Cut a slot in the mounts rather than drill a 1/4" hole, and they slide right on and tighten right up.
http://www.rockler.com/product.cfm?p...2&site=ROCKLER
  #27   Spotlight this post!
Unread 22-01-2013, 00:09
Mugurussa675 Mugurussa675 is offline
FRC #0675
Team Role: Driver
Rookie Year: 2011
Mugurussa675 is on a distinguished road
If you use a welded aluminum/steel chaise you can use C-Chanel that is attached to to the bumpers then drill holes in the chaise and use quick release pins.
FRC Team 675
Drive team
Team Leader
Manufacturing Leader
