Go to Post As an adult who has spent years working with youth in Boy Scouts and FIRST, and on behalf of all other adults at the event: deodorant. - Rick TYler [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 21-12-2012, 10:04
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
smcmahon is an unknown quantity at this point
Question [FTC]: Tetrix Servo Joint Pivot Brackets
http://parts.ftcrobots.com/store/detail.aspx?ID=6302
How do you assemble these things??
We tried it as shown in the image attached. The little screw that goes through the bearing stops the servo from sitting down all the way in it's bracket.
#confused
Unread 21-12-2012, 12:52
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Re: [FTC]: Tetrix Servo Joint Pivot Brackets
Solution acquired!
Mr. Gardner from FTC 6124 was kind enough to share this Tetrix resource:
http://tetrixrobotics.com/Building_S...?art=3205&ap=3
FRC 2656 | FTC 5526 | VEX 9656
Unread 21-12-2012, 15:35
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Meh, still not lining up quite right. I bored out the hold in the bottom of the servo bracket and dropped the bearing through, but it's too short to catch the whole other edge of the pivot bracket...
Unread 21-12-2012, 23:41
CougarRobot CougarRobot is offline
FTC #4251 (Cougar Robotics)
Team Role: Coach
Rookie Year: 2007
CougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to behold
Are you using 485 servos? The brackets pictured were designed for the 475 servos, which were just a little bit thinner than the 485s. We have found that we have to bend the servo bracket open just a little bit (and then back to parallel, just farther apart), and then the pivot bracket open just a little bit, to make it all work. I don't think you want to enlarge the whole on the back of the servo bracket.
Unread 26-12-2012, 02:18
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Just go to Servo City and get the Hitec model FTC approved CNC machined servo block for ~$27. It ia a way more serious design.
http://www.servocity.com/html/standa...rvoblocks.html
Be sure to get the hole pattern hub adaprer ring for attachng the FTC/Tetrix hole pattern parts, as their hole pattern is slightly larger than the Tetrix one.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
