WindRiver Connections not connecting
We have been trying unsuccessfully to get a WindRiver target server connection to work. Unfortunately, each time the connection fails because WindRiver hangs at the step "Checking license" until it times out:
Sun Dec 23 14:41:02 2012 Target name is 10.31.30.2 tgtsvr (VxWorks6x_10.31.30.2_0@home-PC): Sun Dec 23 14:41:02 2012 Wind River Target Server for Workbench 3.3.1 WTX Library version: 4.2.0.46 Tgtsvr core version: 4.2.0.40 Wind River Target Server: Win32 version Connecting to the target agent ... ... switching to WDB4 mode ... ... succeeded ! Loading plug-in for VxWorks... succeeded. Checking License... We have tried reimaging it multiple times without any luck. Our target server options are: Backend Settings: Processor: MPC5200 Backend: wdbrpc Target name or address: 10.31.30.2 Kernel image: File: C:\WindRiver\WPILib\cRIOFRCII_vxWorks Any help would be greatly appreciated! |
Re: WindRiver Connections not connecting
EDIT: We have solved (?) the problem.
I'm really unsure as to what actually happened, but here's what we did: First, we reimaged the CRIO to LabVIEW (Which is the language we used last year). Our LabVIEW code ran perfectly. Then, we reimaged again to C++, and, for some reason, it worked. Would any other programmers out there have insight towards this strange phenomenon? I should add that yesterday our C++ code worked perfectly. Today we reimaged the CRIO to C++ (yes, again), and the problem began, where we could not make a connection from WindRiver. We tried reimaging it to C++ several times, to no avail. We imaged to LabVIEW, ran code, imaged to C++, and it now works. |
