Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 26-12-2012, 12:07
Michael_Lee Michael_Lee is offline
FRC #2976
Michael_Lee is an unknown quantity at this point
Using WindRiver from the command line?
Is there some way of compiling and deploying code from the command line? Our non-programming teammates want to be able to deploy and use code if none of our programmers are present. I've showed several of them how to do it from WindRiver/wrote step-by-step instructions, but I'm looking for a way to simplify the process.
I'm fairly certain deploying the code is just a matter of using ftp to transfer the compiled file to the cRio. Which folder should I place the compiled file in?
