Go to Post Dear Mr. Lavery, Congratulations. For the fourth year running, you have successfully ruined my Christmas holiday with your untimely release of a most obfuscating, but no less tantalizing, hint. - dubious elise [more]
Unread 12-26-2012, 12:32 PM
Michael_Lee Michael_Lee is offline
FRC #2976
Michael_Lee is an unknown quantity at this point
Questions about Encoders and PIDControllers
I'm attempting to implement a PID loop using Encoders and Jaguars by using the PIDController class. We've set up the Encoders to report the rate when PIDGet(); is called. (We currently don't have CAN set up, so that's not an option).
What units should the reported rate be in? Should they be calibrated using 'SetDistancePerPulse()' so they return a range from -1.0 to 1.0 (the same range the Jaguars use)? Or should I not calibrate them at all and leave the encoders alone?
If I use 'SetSetpoint(1.0)', does that mean the PIDController class will try and output some number to the Jaguars so that the encoders eventually report '1.0'?
