pic: WCD
Re: pic: WCD
First, thanks for posting this. I really like the orange and black paint job; we might be doing something similar this year.
I've got a couple of questions about your implementation of the WCP DS. What center drop did you use? Why did you decide to put the gearbox pockets in your bellypan so far in? In the DT I'm working on, with a 3/16" drop, the pancake cylinders will clear the belly pan by a few hundredths. Also, I believe the DS comes fully anodized black, so you might not be able to make the gearbox plates orange. Finally, if you're doing a waterjetted bellypan, why don't you put the electronics on it? Your slide out electronics board is certainly cool, but having it with the bellypan (where most teams put their electronics) seems redundant. Is the bellypan where you're planning on putting your pneumatic system? |
Re: pic: WCD
Just one thing on the DT, I can't see but I just want to make sure you have the bearing blocks really well connected inside the tube. On a prototype last year we just had 3/8 plate on each side with spacers and they would wouldn't always be lined up correctly.
Besides that the drive looks like a run of the mill WCD and I'm sure it'll work if it's made well. As for the electronics, what's supporting the PD board? It looks like it's just on 1/8 polycarb. You might want to think about supporting it because it looks like it'll bounce around a lot and that might looses up connections. |
Re: pic: WCD
By the looks of your design I assume it's welded together?
Looks pretty slick, can we get some more photos of the electronics area? |
Re: pic: WCD
We work very closely with 1515, so I feel like I can speak a little about this drive. The mortorq electronics system is modular. It's very nice to have, but quite heavy. Basically both Mathew and I have tried to get Mortorq to use a regular electronics(non-modular) bellypan, but so far they have been resistant to the change. This isn't the final iteration actually though.
The bearing blocks(at least on this iteration) should be fine. They are the 973/1323 bearing blocks. |
Re: pic: WCD
Instead, we are using a waterjet 1/16" ABS bellypan with a few large pockets rather than the conventional diamond pattern. As to the electronics, 1515's electronics for the past 3 years have utilized c-channel slides and either a reinforced corroplast or polycarbonate. We use WAGO X-comm modular terminal blocks to allow us to easily remove all the electronics in a matter of seconds. Is this level of modularity necessary, or perhaps even desired? No. However, it is a technique that has worked for our team in the past and we do intend to continue modularity in electronics in the future. It is something that our programmers and electrical students both very much appreciate as it allows them to work independently and free of debris. The bearing blocks are very similar to the 973/1323 ones as Michael said, but with a different bolt pattern. Please note that while this is a "standard" wcd frame, a much more recent iteration (except for the abs bellypan) is found here. EDIT: Also, the WCP gearboxes are anodized black and colors in both this rendering and that of our latest revision are simply for the sake of the rendering. (I actually helped with the WCP renderings). Last edited by msimon785 : 12-29-2012 at 05:49 PM. |
Re: pic: WCD
I ask because we're contemplating doing something very similar for our 2013 drive. Here's a screenshot of the setup we're thinking of: http://puu.sh/1H1fU. We would have 2 3/8" plates on either side of the tubing, pocketed so they fit over 2x1 tubing. They would be kept parallel by the 4 10-32 button heads running between the plates, the shaft itself, and the tensioning screw in each plate. |
Re: pic: WCD
We had two 3/8 plates that fit halfway into pocketed tube and two bolts with spacers holding them together. Tensioning was done with a bolt from the end of the box beam to one of the two spacers. With the chain pulling one way and the tensioner pulling the other, the shaft ended up at a slight angle. It still ran fine and wan't much of a problem but it probably put additional load on the bearings.
For the season we machined one big spacer that pocketed into each plate and partially held the bearing on each side. Because both bearings where in once piece they stayed in line. |
Re: pic: WCD
Do you have to take the transmission apart to change a belt?
#10
Re: pic: WCD
Those look like chains. Why 2 sprockets on the ends?
#11
Re: pic: WCD
DampRobot, I reccomend looking at 973's CADs and checking out their bearing blocks. They are super easy to machine and are 1 piece. The side plates can be made simpler if need be(that's what we did last year), but if you have a waterjet sponsor they can do it too.
The WCD is a chain drive. It looks like belt because chain made in solidworks is a solid piece. I'm not sure why the extra sprocket is there and a spacer would probably be in it's place. |
#12
Re: pic: WCD
One thing that we on 2733 learned the hard way with our first WCD was that everything needs to be easily removable. Our bellypan didn't have large enough cutouts in it to accommodate the transmissions when we were trying to get them out. Our second version (used at Bunnybot this year) had cutouts that were as big as we could make them without compromising the rigidity of the frame. It saved weight and friendships .The basic rule for us: the pockets are cut to measure at least the length of the transmission (tip of shaft to end of the cylinder or motor, depending on the mount) plus one inch. |
#13
Re: pic: WCD
It's usually far easier to service drivetrain components for the bottom instead of the top. Then you can build whatever you want on top without worrying about service. Fully removable gearboxes are also nice because you can work outside of the machine entirely, and you always want to be able to completely replace critical assemblies with spares without possibly forgetting a washer (or bearing .In fact, with recent drivetrain development, we've heavily prioritized bottom access to key components, especially chassis maintenance points. When game mechanisms get added on top, it's too hard to access many of them from the top. |
#14
Re: pic: WCD
Michael is right, those are "chains". I actually made this one in Inventor though. The second sprocket is, embarrassingly, a case of laziness. Now that I use SolidWorks, however, I use a configuration for the sprockets so that each wheel/bearing block assembly only has the single appropriate sprocket.
Also, in the current revision, the shafts are chamfered at the end as per the WCP Design. Thank you for the suggestions regarding opening up the bottom. I will make sure to leave clearance pockets for maintenance purposes. |
#15
Re: pic: WCD
On the other hand, if two piece (rather than 3 pieces) are hard to keep aligned, and this misalignment will significantly impact performance, a 973 (or 254, for that matter) style bearing blocks are the best option. I just wasn't really aware that this could be a large problem, and want to make sure that we don't make any drivetrain decisions that we'll regret next year. Sorry for hijacking the thread, I just want to learn a bit more about the ins and outs of WCD bearing blocks, like the ones featured in this design. |
