Go to Post There is no offseason. - Jeff Rodriguez [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 01-01-2013, 16:00
AlecMataloni AlecMataloni is offline
Excellence is Bliss
FRC #0111 (WildStang)
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Problems with converting .step assemblies
Currently I'm having an issue whenever I try to use any recently saved assembly that has been converted from .step to .sldasm.
First, I download any step file with more than one part involved (let's just use the vexpro ball shifter as an example).
Then, I unzip the folder and open the model. It generates with no issues, and everything works great. I save everything in the model to a folder on my desktop, then completely exit my session of Solidworks. No problems yet.
This is where things get strange. I open a new session of Solidworks, and select the recently closed assembly file. The file opens, and suddenly every component in the assembly is permanently suppressed. I try unsuppressing each of the components but it simply doesn't work. I can access each individual piece of the assembly through the feature tree (as long as it's a .sldprt), but they won't display themselves in the assembly for some unknown reason.
When my cursor hovers over each suppressed part, solidworks says that "the file for this component cannot be located", even though when I open the part through the feature tree, it opens with no problems.
Has anyone else had this issue before? It's been happening to me every time I've tried to do this, including when I had Solidworks 2011 installed (I've since upgraded to 2012). If so, would you recommend any course of action?
