Go to Post Remember, let function drive design, not the other way around. - Tom Bottiglieri [more]
Unread 02-01-2013, 09:46
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
Team Role: Teacher
1493kd will become famous soon enough
2013 KB on steriods
So I think I have convienced my team that we need to go with the Kitbot on steriods. From what I have seen/heard this years kit bot will have belts instead of chain drive. I have no experience with belt drive and was wondering how this will change the setup of the KB on steriods. Does anyone have any suggestions to help us with this. Any help will be appreciated.
Unread 02-01-2013, 11:10
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: 2013 KB on steriods
"If your team decides to receive the 2013 KOP Drive System, you will receive an AndyMark C-Base chassis system similar to the last few years. It will again be a six wheel drive robot, with similar wheels to 2012, and with enough material to drive all six wheels. The 2013 gearbox is a ToughBox Mini with 10.71:1 reduction. The estimated final drive speed is about 10 feet per second."
The Toughbox Mini also accepts 2 CIMs so if you elect to drive each side 2 CIMS it will be very similar to the kitbot on steroids from previous years, just theoretically more efficient and lighter.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 02-01-2013, 12:46
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Team Role: Teacher
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
EDIT: FOund the link to the information you are referencing above.
How do you know for sure that the KOP will be the same as last year in regards to the 2013 KOP Drive System?
Was this published already?
Thanks,
Norman
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 02-01-2013, 12:54
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
The main advantage of the KBoS in my mind are the AM shifters and the extra strength from the plywood. The main unknown at this point, which could determine the possibility of running a KBoS system, is the bore of the new pulleys. The output shaft on the AM shifter is 1/2" keyed, and as much as I hope that the new pulleys will be hex, this would prevent them from going in a AM shifter. I guess we'll all find out when the Kit Bot is released tomorrow.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 02-01-2013, 13:37
Andrew Lawrence
Posts: n/a
I'm pretty sure the KBoS uses the kit CIMple Boxes, and where did you hear about the Kitbot being released tomorrow?
Unread 02-01-2013, 14:04
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Rookie Year: 2011
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
I think they switched to Nano Toughboxes this year.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 02-01-2013, 14:13
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
From post #2
Unread 02-01-2013, 14:12
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Where you'd expect, actually. "AndyMark Drive Base Kit...Checklist (coming 1/2/13)" [so actually today, now]. Rather odd, but there. Let's see if it happens.
Unread 02-01-2013, 14:46
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
I agree today "should" be the date the Checklist is available, BUT, has anyone actually seen it yet?
I checked the FIRST 2013 KOP site, but nothing is there yet. And nothing on AndyMark yet either.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 02-01-2013, 14:16
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Ok, I will volunteer the collective advice on behalf of the all the FRC participants and mentors who are face-palming while reading this post. If you have genuinely "decided" or "convinced your team" what drive chassis you will use this year before even seeing the game, your team may want to fundementally rethink your approach to this activity.
Unread 02-01-2013, 15:18
1493kd's Avatar
kd
FRC #1493 (FALCONS)
Team Role: Teacher
Why is this so? We have had sub par results in our 10 years of doing it the way that we have. We dont have enough resources to devote time to custom things and would be better served using the provided frame. The rest of the team felt that this would be a good approach. I am reaching out to the chiefdelphi community asking for advice. Before I face palm in frustration could you please explain to me how my fundementals need to be rethought?
Unread 02-01-2013, 15:25
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
I believe he's referring to the fact you make design decisions before kickoff, not criticising the decision itself.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 02-01-2013, 15:34
Andrew Lawrence
Posts: n/a
What Jeff is trying to say is you can't say you are doing a specific design for sure without even knowing what the game is. My favorite example of this is 2009, the game with regulation wheels and a low-friction playing field. If your team decided that you'd use 4" wheels and the kitbot for the 2009 season without knowing what the game was, come kickoff day you'd be disappointed to find that due to rules, restrictions, and the way the game was played, that the chassis you decided on using either isn't allowed, or isn't the best solution to the game.
He isn't saying that you shouldn't decide to use the kitbot and go custom. He's saying that you shouldn't make any decisions before you've seen the game and decided your strategy. This year we wanted a long robot (kitbot on steroids, to be exact) before seeing Rebound Rumble. After seeing it, we decided a wide robot would be advantageous for us due to more room on the bridge and a wider pickup area.
Unread 02-01-2013, 15:35
billbo911's Avatar
Why is this so? .... Before I face palm in frustration could you please explain to me how my fundementals need to be rethought?
I believe his intent was to suggest not placing all your eggs in one basket quite yet.
Until we really know what the game is, it would be very prudent to NOT commit to any design specifics just yet.
As an example:
If you had decided and committed to make a high torque, multi-speed drive train before kickoff in 2009, when Lunacy was introduced, you would find you had shot yourselves in the proverbial feet.
The game can dictate different aspects of a drive-train.
Now, based on what we KNOW is included in the KOP this year, the assumptions on the needs of the drive-train for 2013 can be narrowed down quite a bit.
4" high grip wheels, ToughBox Mini transmissions with 10.7:1 reduction, belt drive up to 6 wheels, from the KOP. Based on those facts, you should be able to get fairly close to a final decision without even seeing what the game is.
But, nothing should be set in stone just yet.
  #15   Spotlight this post!
Unread 02-01-2013, 21:11
alb4h alb4h is offline
FRC #3862
alb4h is an unknown quantity at this point
[quote=billbo911;1206564] .....snip....
Where did you get this info? How do you know what's in the KOP already?
Ann
