Go to Post FRC isn't for every school; it takes a lot of drive just to fundraise every year. It is a premium program that requires a premium about of effort to sustain and be successful. And man is it fun to do. - JesseK [more]
Unread 03-01-2013, 11:20
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Mentor
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2012
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Digital Side Car Issue with Encoder
We are having an issue with a USDigital S4 encoder... when the A channel is plugged into the DSC DIO port 1 and the B channel plugged into port 2 it properly provides an output using getRaw() when the DS is disabled. As soon as the DS is enabled, the output count oscillates between the last disabled value and last disabled value + 1. If we plug the same encoder into ports 9/10, 11/12, or 13/14 it works fine both disabled and enabled.
I checked the wiring twice for both continuity between ends and the proper pin order. The voltage at the +/gnd pins is 5v for all ports when the DS is both disabled and enabled.
Any ideas what might be going on?
