Go to Post It's not about the robot. It's about science, technology, engineering, and mathematics. - Ether [more]
Unread 04-01-2013, 13:45
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: Sheet Metal, 8-Wheel Drive Design
Originally Posted by jwfoss View Post
In the attachment below, I quickly drew up a set of chassis rails (looking at the robot from the front). The left side shows the configuration used by the original poster. In this configuration the height of the rails is determined by the height of the gearbox to avoid having to remove a section of the flange. The right shows the flange flipped the other way. Doing this allows height of the rails to be independent of transmission, and allows the mounting of a tower to the internal surface, while retaining a full flange.
There are many ways to configure the rails, our most recent concept has the outer c rail flipped as well. You can see some of FRC2168s cad development as well as some of our past designs by reading my blog (click my name in my signature).
Please let me know if this needs further discussion.
Thanks; that is was I suspected you might've meant, but wanted to be sure. I think that I'd likely mount structure to the drive by sitting it atop the flanges rather than by abutting the inside face, so it hadn't occurred to me that the flange might get in the way.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 06-01-2013, 14:53
seinchin seinchin is offline
AKA: Kevin
FRC #4144 (Semi-Con-Duck-tors)
Team Role: Coach
seinchin is an unknown quantity at this point
27x33 in long configuration translates to 120 total inches on the frame perimeter. The rules this year limit you to 112 inches on the frame perimeter.
Student on FRC 1014: Bad Robots -- 2006-2007
Mentor for FRC 1014: Bad Robots -- 2008-2011
Coach for FRC 4144: Semi Con-Duck-Tors -- 2012 - ?
Unread 06-01-2013, 17:48
n1ckd2012's Avatar
n1ckd2012 n1ckd2012 is offline
oRyon Labs
AKA: Nick Dulworth
FRC #2587 (DiscoBots)
Rookie Year: 2010
n1ckd2012 will become famous soon enoughn1ckd2012 will become famous soon enough
A new chassis, based on this one, is in the works. It complies with this year's dimensions. It is 6WD wide with 4inch Colsons and the VEXPRO 6 Cim gearboxes.
Ri3D Team oRyon, 2014-Present
Ri3D 2015: Betelgeuse | Ri3D 2014: Draconis
2587 DiscoBots, 2010-Present
FRC 2012: Laser Dragon, Film, Build Log, Lone Star 3rd Seed Alliance
Vex 2012: Mini Dragon, Film, Math Division Finalists
FRC 2011: DiscoSlide, Film, 118 Parody, Lone Star Regional Finalists
Unread 06-01-2013, 17:53
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Do you plan on driving that with 6 CIMs? We were looking into using that gearbox with 2 CIMs and something else...maybe a 775 through a planetary, or a BAG motor put through something(VersaPlanetary won't work for this, right? EDIT: Nevermind, I just saw that there is a CIM output kit)
Last edited by Steven Donow : 06-01-2013 at 17:57. Reason: actually looked at VersaPlanetary product page
